VAG-COM 607..
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
tartan_rob
VAG-COM 607..
Post by tartan_rob » Fri Jan 12, 2007 12:43 pm
Anyone in Wiltshire got this and can run a test on my car to see if they can access Sat Nav? I have the older VAG-Com version and before I go and buy a newer copy, I wanted to check it worked on the functions that I cannot currently access.
Thanks,
Rob
2017 Kawasaki Z1000
2014 RS6
2014 S1
jfeb
RE: VAG-COM 607..
Post by jfeb » Fri Jan 12, 2007 5:05 pm
Rob. Not quite Wiltshire but I work in Theale (J12 of the M4). If you are in that neck of the woods I'd be happy to help.
DavidT
RE: VAG-COM 607..
Post by DavidT » Fri Jan 12, 2007 5:45 pm
You can download the latest version from their website.
MarkB
Re: RE: VAG-COM 607..
Post by MarkB » Fri Jan 12, 2007 10:35 pm
DavidT wrote:You can download the latest version from their website.
and it will work if you have a recent genuine ROSS-TECH lead...
Mark
DavidT
Post by DavidT » Fri Jan 12, 2007 10:38 pm
Thanks Mark, I must have missed something then ?
MarkB
RE: Re: RE: VAG-COM 607..
Post by MarkB » Fri Jan 12, 2007 10:45 pm
If Rob is running version 409 I would think he needs a newer ROSS-TECH lead or he's using a generic lead.
Mark
ZeroK66
Post by ZeroK66 » Fri Jan 12, 2007 11:45 pm
Yeah you need a Ross-Tech "HEX" lead to run later than v4.
DavidT
Post by DavidT » Fri Jan 12, 2007 11:53 pm
And one should buy a genuine lead, great value for money :)
tartan_rob
Post by tartan_rob » Mon Jan 15, 2007 9:44 am
Yep, I have the old "dumb" lead. I wanted to check the newer VAG-com version worked the sat-nav and other functions before splashing out...
Rob
2017 Kawasaki Z1000
2014 RS6
2014 S1
PetrolDave
Re: RE: Re: RE: VAG-COM 607..
Post by PetrolDave » Mon Jan 15, 2007 6:02 pm
Tartan_Rob wrote:Yep, I have the old "dumb" lead. I wanted to check the newer VAG-com version worked the sat-nav and other functions before splashing out...
Rob
607.3 and a HEX-COM+CAN lead lets me access all the controllers (including both engine ECUs [the RS4 has one per bank], RNS-E and phone) on my 2006 RS4.
tartan_rob
RE: Re: RE: Re: RE: VAG-COM 607..
Post by tartan_rob » Mon Jan 15, 2007 6:43 pm
HEX-COM+CAN is the serial port on the laptop right?
2017 Kawasaki Z1000
2014 RS6
2014 S1
DavidT
Re: RE: Re: RE: Re: RE: VAG-COM 607..
Post by DavidT » Mon Jan 15, 2007 6:50 pm
Tartan_Rob wrote:HEX-COM+CAN is the serial port on the laptop right?
Not sure, I think all the newer ones are USB Rob.
MarkB
RE: Re: RE: Re: RE: Re: RE: VAG-COM 607..
Post by MarkB » Mon Jan 15, 2007 8:13 pm
Your right Rob
Hex-com + can is serial port. check ross-tech site to be sure
Mark
ZeroK66
Post by ZeroK66 » Mon Jan 15, 2007 9:29 pm
I have hex-com+CAN brand new lead and mine is USB.
PetrolDave
Post by PetrolDave » Mon Jan 15, 2007 10:16 pm
You can order HEX-COM+CAN which is for a serial port, or the more expensive HEX-USB+CAN which is for USB.
Or even the cheaper micro-CAN - but this is for CAN ONLY cars like the Golf V, 8P A3, 8J TT, etc.
Or if you don't want any CAN capability the KEY-COM for a serial port, or the more expensive KEY-USB for USB.
http://www.ross-tech.com/Merchant2/merc ... ode=VAGCOM
Return to “DTC / VCDS”
Users browsing this forum: No registered users and 52 guests
