Intake Pressure-Tester
General Forum for Warranty, Dealers, Servicing, Insurance, Breakdown, etc
MCB
Post by MCB » Thu Dec 21, 2006 2:29 pm
:thumbs:
S4B5 Avant
kylewc
Post by kylewc » Thu Dec 21, 2006 3:14 pm
Oh yeah... great minds ;-)
MCB
Post by MCB » Thu Dec 21, 2006 3:55 pm
:lol:
S4B5 Avant
shineydave
Post by shineydave » Thu Dec 21, 2006 11:07 pm
do you mean something like this.....................
UKS4APR1
Post by UKS4APR1 » Fri Dec 22, 2006 12:46 am
shineydave wrote:do you mean something like this.....................
Perfect!
Please start production :bigblink:
S4TAN
Post by S4TAN » Fri Dec 22, 2006 2:24 pm
Put me down for one! :thumbs:
Deus ex machina
shineydave
Post by shineydave » Sat Dec 23, 2006 8:57 am
not had time to test it much, i tried pressurising it with a 12v tyre inflator but it wouldn't produce the volume of air required. now i've made up a pipe with a schrader adapter on each end so i can use the spare tyre as a pressure source. might have a go this weekend whilst 'er indoors is wrestling with the turkey
UKS4APR1
Post by UKS4APR1 » Sat Dec 23, 2006 10:12 pm
shineydave wrote:not had time to test it much, i tried pressurising it with a 12v tyre inflator but it wouldn't produce the volume of air required. now i've made up a pipe with a schrader adapter on each end so i can use the spare tyre as a pressure source. might have a go this weekend whilst 'er indoors is wrestling with the turkey
Nice Idea, however I have a compressor at my disposal - could you make some more testers? :lol:
I prefer your idea to the "drain pipe" idea as long as you get it to seal and hold the pressure OK without popping off!
Think you could make a small killing if you could come up with a few of these to sell.
If the spare tyre/schrader adapter works I think you're on to a winner as the compressed air source is the problem for the majority of the Forum (IMO)
shineydave
Post by shineydave » Sun Dec 24, 2006 2:43 am
i'll test it again with the tyre on sunday and if it works i'll put a price together, the main costs are the pressure gauge, the rest of it is fairly cheap, just really my time to put the components together
UKS4APR1
Post by UKS4APR1 » Mon Jan 01, 2007 11:14 pm
Come on Dave,
this is a shineydave pressure-tester :boots:
tdiquattro
Post by tdiquattro » Tue Jan 02, 2007 8:06 am
I would like to buy one too, if there are enough to go round, :)
good job Dave!
Nige'
2000 silver S4 Saloon
UKS4APR1
Post by UKS4APR1 » Mon Jan 08, 2007 2:21 am
OK I've made up my version of the pressure tester (see photos)
It incorporates a 0-2 bar (0-30psi) gauge and a tyre valve. It fits on the end of the Y-pipe as I decided the accordian hose pipe looked a bit suspect to take 1 bar pressure. I have also come up with an end-cap to seal the PCV branch-off.
I have tried it out on my car and it all works. Simply attach an air-line tyre inflator (a foot pump wont do it) from a small compressor (12v wont do it either I don't think) and pump up the system exactly as if you were pumping up a tyre. Keep watching the pressure gauge and stop before 1 bar pressure. It is possible to then remove the air-line.
The pressure should SLOWLY DROP as air leaks past the pistons into the crankcase, you can hear a bubbling noise and slight hiss at the oil filler cap. Whilst the system is pressurised you can search for any leaks. If you have a bad leak it's possible to keep the air-line connected to keep the pressure up, all the time watching the gauge to maintain the correct pressure.
Right, whist making this one, I decided to make some more at the same time, including the SEAL CAP for PCV branch-off
If any of you who expressed an interest would like one, please send me a PM. Unfortunately they are not free!! I think I would be prepared to make another batch if there is a demand and people are happy with it.
Please Note I am not responsible for it's use and you do so at your own risk.
IPT on car.jpg (91.19 KiB) Viewed 880 times
IPT + Cap.jpg (68.55 KiB) Viewed 880 times
GrahamS4
Post by GrahamS4 » Mon Jan 08, 2007 7:37 am
Nice!
shineydave
Post by shineydave » Mon Jan 08, 2007 7:57 pm
not bad at all. i've fitted a 1.6bar (0-24psi) gauge now and a one way valve. just need a dry day for another test. is that the rubber off of a walking stick you've used for the PCV stopper?
MCB
Post by MCB » Mon Jan 08, 2007 9:10 pm
Fine peice of work!
S4B5 Avant
Return to “Audi S and RS Ownership”
Users browsing this forum: No registered users and 39 guests
