Intake Pressure-Tester
- shineydave
do you mean something like this.....................
- Attachments
- 696H0529.jpg (34.72 KiB) Viewed 1002 times
Dave
- shineydave
not had time to test it much, i tried pressurising it with a 12v tyre inflator but it wouldn't produce the volume of air required. now i've made up a pipe with a schrader adapter on each end so i can use the spare tyre as a pressure source. might have a go this weekend whilst 'er indoors is wrestling with the turkey
Dave
Nice Idea, however I have a compressor at my disposal - could you make some more testers?shineydave wrote:not had time to test it much, i tried pressurising it with a 12v tyre inflator but it wouldn't produce the volume of air required. now i've made up a pipe with a schrader adapter on each end so i can use the spare tyre as a pressure source. might have a go this weekend whilst 'er indoors is wrestling with the turkey
I prefer your idea to the "drain pipe" idea as long as you get it to seal and hold the pressure OK without popping off!
Think you could make a small killing if you could come up with a few of these to sell.
If the spare tyre/schrader adapter works I think you're on to a winner as the compressed air source is the problem for the majority of the Forum (IMO)
- shineydave
i'll test it again with the tyre on sunday and if it works i'll put a price together, the main costs are the pressure gauge, the rest of it is fairly cheap, just really my time to put the components together
Dave
- tdiquattro
OK I've made up my version of the pressure tester (see photos)
It incorporates a 0-2 bar (0-30psi) gauge and a tyre valve. It fits on the end of the Y-pipe as I decided the accordian hose pipe looked a bit suspect to take 1 bar pressure. I have also come up with an end-cap to seal the PCV branch-off.
I have tried it out on my car and it all works. Simply attach an air-line tyre inflator (a foot pump wont do it) from a small compressor (12v wont do it either I don't think) and pump up the system exactly as if you were pumping up a tyre. Keep watching the pressure gauge and stop before 1 bar pressure. It is possible to then remove the air-line.
The pressure should SLOWLY DROP as air leaks past the pistons into the crankcase, you can hear a bubbling noise and slight hiss at the oil filler cap. Whilst the system is pressurised you can search for any leaks. If you have a bad leak it's possible to keep the air-line connected to keep the pressure up, all the time watching the gauge to maintain the correct pressure.
Right, whist making this one, I decided to make some more at the same time, including the SEAL CAP for PCV branch-off
If any of you who expressed an interest would like one, please send me a PM. Unfortunately they are not free!! I think I would be prepared to make another batch if there is a demand and people are happy with it.
Please Note I am not responsible for it's use and you do so at your own risk.
- Attachments
- IPT on car.jpg (91.19 KiB) Viewed 886 times
- IPT + Cap.jpg (68.55 KiB) Viewed 886 times
- shineydave
not bad at all. i've fitted a 1.6bar (0-24psi) gauge now and a one way valve. just need a dry day for another test. is that the rubber off of a walking stick you've used for the PCV stopper?
Dave
Users browsing this forum: No registered users and 55 guests
