VCDS - RNS-E
- 1st Gear
VCDS - RNS-E
Hi Folks,
Having difficulty in getting the VAGCOM to communicate with the RNS-E setup in my 2007 RS4, hopefully someone can shed some light?
I've tried the following;
17-Instruments
10-Adaptation
63-21
Even after all that, I still cannot access either 37-Navigation or 56-Radio.
I'm using a full VCDS Hex+Can+Dual-K cable which is bought from Ross-tech. Latest software version 805.1 and the RNS-E is on SW0060.
Unit is original with the car. Ideas? TIA.
17-Instruments
10-Adaptation
63-21
- Virdee Autos
- Trader (Expired)
RE: VCDS - RNS-E
Very strange
Obviously your RNS-E is working/functioning?
And have you tried to access other modules, i.e. engine, ABS, etc?
Virdee Autos ~ 07950-526592
- PetrolDave
Re: VCDS - RNS-E
If you have SW0060 in your RNS-E then it's a pretty old unit, which would imply that it wasn't factory fitted. In that case you must have fitted a wiring adapter to convert from the ISO connectors of the OE radio to the Quadlock of the RNS-E. I would guess that the K-line is not correctly connected in the wiring adapter (a pretty common fault in these adapters).primus2211 wrote:I'm using a full VCDS Hex+Can+Dual-K cable which is bought from Ross-tech. Latest software version 805.1 and the RNS-E is on SW0060.
Pinouts are on labels on the top of the RNS-E and the OE radio.
- 1st Gear
Re: VCDS - RNS-E
Strange...hmm...the car comes with the "7Q2" option though which indicates factory fitted satnav unit. No matter, time to get dirty and start yanking things out!PetrolDave wrote: If you have SW0060 in your RNS-E then it's a pretty old unit, which would imply that it wasn't factory fitted
Virdee Autos,
Yup, did a full scan, everything else works except for the RNS-E. Got me stumped as well but guessing by PetrolDave's comment, might be worth the effort to pull the unit to have a look at the wiring.
Thanks for the feedback!
- PetrolDave
Re: VCDS - RNS-E
Sounds like you might have mis-typed 0060 instead of 0600 then...primus2211 wrote:Strange...hmm...the car comes with the "7Q2" option though which indicates factory fitted satnav unit. No matter, time to get dirty and start yanking things out!PetrolDave wrote: If you have SW0060 in your RNS-E then it's a pretty old unit, which would imply that it wasn't factory fitted
- 1st Gear
Re: VCDS - RNS-E
Ooopss...you're right, the version is actually SW0600. Thanks for the correction. In that event, any idea what could be the problem? Still wiring?PetrolDave wrote:Sounds like you might have mis-typed 0060 instead of 0600 then...
Thanks!
- PetrolDave
Re: VCDS - RNS-E
Since we know it's a factory fitted unit then I reckon that leaves two possibilities (the K-line must have been connected for them to code the RNS-E at the factory):primus2211 wrote:In that event, any idea what could be the problem? Still wiring?
1)the K-line (which is used for diagnostics) has become disconnected or broken between the diagnostics socket and the RNS-E; or
2) the RNS-E has become faulty.
First thing I would do is pull the RNS-E and with a multimeter check the resistance between the K-line pin of the RNS-E (see the paper label on the top of the RNS-E for the pinout) and the L-line on the diagnostics socket. Yes, that's right the K-line of then RNS-E connects to the L-line and not the K-line at the diagnostics socket.
- 1st Gear
