VCDS - RNS-E
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
primus2211
VCDS - RNS-E
Post by primus2211 » Mon Oct 20, 2008 6:24 am
Hi Folks,
Having difficulty in getting the VAGCOM to communicate with the RNS-E setup in my 2007 RS4, hopefully someone can shed some light?
I've tried the following;
17-Instruments
10-Adaptation
63-21
Even after all that, I still cannot access either 37-Navigation or 56-Radio.
I'm using a full VCDS Hex+Can+Dual-K cable which is bought from Ross-tech. Latest software version 805.1 and the RNS-E is on SW0060.
Unit is original with the car. Ideas? TIA.
Virdee Autos
Trader (Expired)
RE: VCDS - RNS-E
Post by Virdee Autos » Mon Oct 20, 2008 7:07 pm
Very strange
Obviously your RNS-E is working/functioning?
And have you tried to access other modules, i.e. engine, ABS, etc?
Virdee Autos ~ 07950-526592
PetrolDave
Re: VCDS - RNS-E
Post by PetrolDave » Mon Oct 20, 2008 7:22 pm
primus2211 wrote:I'm using a full VCDS Hex+Can+Dual-K cable which is bought from Ross-tech. Latest software version 805.1 and the RNS-E is on SW0060.
If you have SW0060 in your RNS-E then it's a pretty old unit, which would imply that it wasn't factory fitted. In that case you must have fitted a wiring adapter to convert from the ISO connectors of the OE radio to the Quadlock of the RNS-E. I would guess that the K-line is not correctly connected in the wiring adapter (a pretty common fault in these adapters).
Pinouts are on labels on the top of the RNS-E and the OE radio.
primus2211
Re: VCDS - RNS-E
Post by primus2211 » Tue Oct 21, 2008 3:11 am
PetrolDave wrote: If you have SW0060 in your RNS-E then it's a pretty old unit, which would imply that it wasn't factory fitted
Strange...hmm...the car comes with the "7Q2" option though which indicates factory fitted satnav unit. No matter, time to get dirty and start yanking things out! :D
Virdee Autos,
Yup, did a full scan, everything else works except for the RNS-E. Got me stumped as well but guessing by PetrolDave's comment, might be worth the effort to pull the unit to have a look at the wiring.
Thanks for the feedback!
PetrolDave
Re: VCDS - RNS-E
Post by PetrolDave » Tue Oct 21, 2008 12:22 pm
Sounds like you might have mis-typed 0060 instead of 0600 then...
primus2211
Re: VCDS - RNS-E
Post by primus2211 » Wed Oct 22, 2008 12:30 am
PetrolDave wrote:Sounds like you might have mis-typed 0060 instead of 0600 then...
Ooopss...you're right, the version is actually SW0600. Thanks for the correction. In that event, any idea what could be the problem? Still wiring?
Thanks!
PetrolDave
Re: VCDS - RNS-E
Post by PetrolDave » Wed Oct 22, 2008 6:43 pm
primus2211 wrote:In that event, any idea what could be the problem? Still wiring?
Since we know it's a factory fitted unit then I reckon that leaves two possibilities (the K-line must have been connected for them to code the RNS-E at the factory):
1)the K-line (which is used for diagnostics) has become disconnected or broken between the diagnostics socket and the RNS-E; or
2) the RNS-E has become faulty.
First thing I would do is pull the RNS-E and with a multimeter check the resistance between the K-line pin of the RNS-E (see the paper label on the top of the RNS-E for the pinout) and the L-line on the diagnostics socket. Yes, that's right the K-line of then RNS-E connects to the L-line and not the K-line at the diagnostics socket.
primus2211
Post by primus2211 » Thu Oct 23, 2008 2:26 am
Thanks for the pointers, waiting for the 4-piece tool from Fleabay. Once that gets in, will have a peek under the RNS-E and check on the K1 and K2 connection. :D
Return to “DTC / VCDS”
