S4 Brakes!!
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
GDS968
S4 Brakes!!
Post by GDS968 » Tue Jul 29, 2008 12:28 pm
My standard 2001 S4 brakes are crap! Have been MRC'd and would like to know if there is a route to upgrade without bigger wheels (although this will no doubt happen at some point) which works effectively. Will just brake pad/discs work? Anyone done this and found it to work.
cheers
Blue_Thunder
RE: S4 Brakes!!
Post by Blue_Thunder » Tue Jul 29, 2008 1:03 pm
Do a search. I think the Porsche brakes fit under 17's. Think these are the ECS ones.
bobbler
Re: RE: S4 Brakes!!
Post by bobbler » Tue Jul 29, 2008 1:23 pm
Blue_Thunder wrote:Do a search. I think the Porsche brakes fit under 17's. Think these are the ECS ones.
The ECS IV wouldn't fit under a lot of 18s let alone 17s. Certainly the standard Avus wheels would stand no chance.
. S4 Nogaro Blue Avant . ECS IV . RS4 handling bits . 18" Ultraleggera . AWE Boost Gauge . MRC Custom Map . 315 BHP . 482 Nm .
SJS
Re: S4 Brakes!!
Post by SJS » Tue Jul 29, 2008 1:57 pm
GDS968 wrote:My standard 2001 S4 brakes are crap! Have been MRC'd and would like to know if there is a route to upgrade without bigger wheels (although this will no doubt happen at some point) which works effectively. Will just brake pad/discs work? Anyone done this and found it to work.
cheers
That was my first impression as well when i moved from a lighter A4 1.8T with cross drilled disks. The brakes on it were good. I found the brakes on the S4 to be nowhere near as quick at slowing the car down. Recently changed the front pads to OEM and theyre marginally better than before but really need new calipers and fast road pads if you really want to slow down quickly.
I too would like to upgrade but cant justify buying all that kit plus four new rims and tyres, sorting the suspension and getting it all re-aligned. Ive just learnt to brake a little earlier :)
Nogaro S4 Yr2000. MRC remap, K04s, Milltek
h8cak
RE: Re: S4 Brakes!!
Post by h8cak » Tue Jul 29, 2008 2:27 pm
B5 RS4 set up. cheep and good
Wide Body S4
GDS968
Post by GDS968 » Tue Jul 29, 2008 2:51 pm
h8cak you need 18inch rims for these don't you?
UKS4APR1
Post by UKS4APR1 » Tue Jul 29, 2008 10:52 pm
Stop Tech 332mm x 32mm BBK will fit under std avus 17" wheels
http://www.stoptech.com/
h8cak
Post by h8cak » Tue Jul 29, 2008 11:42 pm
Yeah true. But with the money u save you can get a cheep set of 18's :)
Wide Body S4
Dippy
Post by Dippy » Wed Jul 30, 2008 12:35 pm
Brakes are an important upgrade. Although I got Porsche brakes to fit under the standard 17" Avus wheels and I am happy with them, I later changed to 18" wheels and in hindsight I wish I'd done wheels and brakes at the same time and could have got a better solution. If you're not ready to upgrade wheels then I actually recommend that you live with the std brakes until you are and then go for brakes to fit 18" wheels.
2001 Silver S4 Avant
rs6red
Porsche Brakes
Post by rs6red » Thu Jul 31, 2008 10:34 am
Hello Dippy
Do you have any more comments etc. on the Porsche brakes. I was looking at these to retain the standard 17 inch wheels and so am keen for any feedback good or bad. What would you have gone to instead if you'd changed to 18 inch wheels.
Steve
SimonS4MTM
Post by SimonS4MTM » Thu Jul 31, 2008 12:33 pm
Nothing wrong with Porcshe brakes, not tried them against B7 and may be a little more expensive but will go in 17's
Justin:NorCal
Post by Justin:NorCal » Fri Aug 01, 2008 1:37 am
Alcon for those wondering under 17s
Users browsing this forum: No registered users and 171 guests
