S4 rods vs RS4 rods
S4 rods vs RS4 rods
Ok, I have RS4 Engine, so RS4 crank ...
Got some Pauter S4 rods and S4 Shells
Here are some diameters
RS4 Rods
Big end inside diameter: 56.60mm
Big end thickness 20.12mm
Big end bearing thickness 1.37
Pauter S4 Rods
Big end inside diameter: 57.51mm
Big end thickness 20.13mm
Big end bearing thickness 1.79mm
Crank thickness where rod attaches 54mm
Now, as far as I can see, the S4 setup is not going to work?? it looks to be a different size???? Can any one confirm???
RS4 Rods
Pauter S4 Rods
satanschild
- 2nd Gear
oops...
hello bud...
i can definatly say that your s4 rods wont fit your rs4 crank....
hows it going with your build..?
RE: oops...
Hold on. IIRC they should fit. Maybe you got wrong bearings? Waiting for Okkim for measures : )
Re: RE: oops...
Slight slant on the thread. Did you get the Titanium rods. If not what id the weight difference between them and the standard rods?viperbl wrote:Was starting to come together until I learnt this!!
RE: Re: RE: oops...
Rich don't worry the RS4 are only different to run bigger bolts, both fit with the right shells, so what you have will work
satanschild
- 2nd Gear
sorry rich ... dummi is right ...
i didn't read your post very well .....duh
they do fit ive just tryed my old ones with a spare rs4 crank ....
rs4 shells dont fit in the s4 rods was what i was thinking
but you have s4 shells ... so your all good bud ...
RE: .
Thanks guys!!! PHEW!!!
But I dont understand why my calcs look way out, it would seem that with the shells on each of them, they are still a different diameter ?? therefore more/less space inbetween the shells and the crank?
Re: RE: .
it seems to simple once exlained, glad its straight in my head now!!!! Now, my calcs work out to 0.07 difference!!! perfect! I can live with that tolerance!dummi wrote:s4 rods are 0.9mm bigger, its shells are thicker by .4 to .45 , one on each side of the shaft makes up that difference.
RE: Re: RE: .
if you were looking at old bearings your bentleys would cover the minimum thickness
