S4 rods vs RS4 rods
viperbl
S4 rods vs RS4 rods
Post by viperbl » Fri Apr 04, 2008 10:07 pm
Ok, I have RS4 Engine, so RS4 crank ...
Got some Pauter S4 rods and S4 Shells
Here are some diameters
RS4 Rods
Big end inside diameter: 56.60mm
Big end thickness 20.12mm
Big end bearing thickness 1.37
Pauter S4 Rods
Big end inside diameter: 57.51mm
Big end thickness 20.13mm
Big end bearing thickness 1.79mm
Crank thickness where rod attaches 54mm
Now, as far as I can see, the S4 setup is not going to work?? it looks to be a different size???? Can any one confirm???
RS4 B5 Saloon8) with 750+ bhp :D
satanschild
oops...
Post by satanschild » Sat Apr 05, 2008 12:45 am
hello bud...
i can definatly say that your s4 rods wont fit your rs4 crank.... :cry:
hows it going with your build..?
viperbl
RE: oops...
Post by viperbl » Sat Apr 05, 2008 1:21 am
Was starting to come together until I learnt this!! :(
smurfbus
RE: oops...
Post by smurfbus » Sat Apr 05, 2008 7:30 am
Hold on. IIRC they should fit. Maybe you got wrong bearings? Waiting for Okkim for measures : )
dazzer
Re: RE: oops...
Post by dazzer » Sat Apr 05, 2008 9:56 am
viperbl wrote:Was starting to come together until I learnt this!! :(
Slight slant on the thread. Did you get the Titanium rods. If not what id the weight difference between them and the standard rods?
dummi
RE: Re: RE: oops...
Post by dummi » Sat Apr 05, 2008 12:54 pm
Rich don't worry the RS4 are only different to run bigger bolts, both fit with the right shells, so what you have will work
satanschild
Post by satanschild » Sat Apr 05, 2008 2:28 pm
sorry rich ... dummi is right ... :D
i didn't read your post very well .....duh :oops:
they do fit ive just tryed my old ones with a spare rs4 crank ....
rs4 shells dont fit in the s4 rods was what i was thinking
but you have s4 shells ... so your all good bud ... :thumbs:
viperbl
RE: .
Post by viperbl » Sat Apr 05, 2008 2:34 pm
Thanks guys!!! PHEW!!!
But I dont understand why my calcs look way out, it would seem that with the shells on each of them, they are still a different diameter ?? therefore more/less space inbetween the shells and the crank?
dummi
RE: .
Post by dummi » Sat Apr 05, 2008 3:18 pm
s4 rods are 0.9mm bigger, its shells are thicker by .4 to .45 , one on each side of the shaft makes up that difference.
viperbl
Re: RE: .
Post by viperbl » Sat Apr 05, 2008 3:51 pm
dummi wrote:s4 rods are 0.9mm bigger, its shells are thicker by .4 to .45 , one on each side of the shaft makes up that difference.
it seems to simple once exlained, glad its straight in my head now!!!! Now, my calcs work out to 0.07 difference!!! perfect! I can live with that tolerance!
dummi
RE: Re: RE: .
Post by dummi » Sun Apr 06, 2008 12:13 am
if you were looking at old bearings your bentleys would cover the minimum thickness
