S4 rods vs RS4 rods
S4 rods vs RS4 rods
Ok, I have RS4 Engine, so RS4 crank ...
Got some Pauter S4 rods and S4 Shells
Here are some diameters
RS4 Rods
Big end inside diameter: 56.60mm
Big end thickness 20.12mm
Big end bearing thickness 1.37
Pauter S4 Rods
Big end inside diameter: 57.51mm
Big end thickness 20.13mm
Big end bearing thickness 1.79mm
Crank thickness where rod attaches 54mm
Now, as far as I can see, the S4 setup is not going to work?? it looks to be a different size???? Can any one confirm???
RS4 Rods
Pauter S4 Rods
satanschild
oops...
hello bud...
i can definatly say that your s4 rods wont fit your rs4 crank....
hows it going with your build..?
RE: oops...
Hold on. IIRC they should fit. Maybe you got wrong bearings? Waiting for Okkim for measures : )
Re: RE: oops...
Slight slant on the thread. Did you get the Titanium rods. If not what id the weight difference between them and the standard rods?viperbl wrote:Was starting to come together until I learnt this!!
RE: Re: RE: oops...
Rich don't worry the RS4 are only different to run bigger bolts, both fit with the right shells, so what you have will work
satanschild
sorry rich ... dummi is right ...
i didn't read your post very well .....duh
they do fit ive just tryed my old ones with a spare rs4 crank ....
rs4 shells dont fit in the s4 rods was what i was thinking
but you have s4 shells ... so your all good bud ...
RE: .
Thanks guys!!! PHEW!!!
But I dont understand why my calcs look way out, it would seem that with the shells on each of them, they are still a different diameter ?? therefore more/less space inbetween the shells and the crank?
Re: RE: .
it seems to simple once exlained, glad its straight in my head now!!!! Now, my calcs work out to 0.07 difference!!! perfect! I can live with that tolerance!dummi wrote:s4 rods are 0.9mm bigger, its shells are thicker by .4 to .45 , one on each side of the shaft makes up that difference.
RE: Re: RE: .
if you were looking at old bearings your bentleys would cover the minimum thickness
