Airbag Light -HELP!!!!
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
Trig
Post by Trig » Thu Feb 21, 2008 8:26 pm
Airbag light came on this morning when the car was started.
Wasn't on last night.
Why has it come on when it aint gone anywhere?
Whats it likley to be?
How can I reset it?
TIA
GardinerG
RE: Airbag Light -HELP!!!!
Post by GardinerG » Thu Feb 21, 2008 8:46 pm
I think you will need to check the fault codes using VAG-COM or similar.
Blue_Thunder
Post by Blue_Thunder » Thu Feb 21, 2008 9:05 pm
Do a search on here. Very common issue.
yorkie
Post by yorkie » Thu Feb 21, 2008 9:22 pm
Will be a dodgy connection under the seat probably, very common.
Normally easily fixed with a bit of wire waggling/terminal cleaning but unfortunately code cannot be cleared without a reset tool such as Vag-Com or various other scanners.
Sure someone on here will be happy to sort it for you - I am but I live in Cambridge.
SonicDeathMonkey
Post by SonicDeathMonkey » Sat Feb 23, 2008 3:41 pm
Happened to be a loose connection under my passenger seat
tartan_rob
Post by tartan_rob » Mon Feb 25, 2008 12:34 pm
Tighten up connection and spray with WD40 etc., I found that helped no end.
2017 Kawasaki Z1000
2014 RS6
2014 S1
Trig
Post by Trig » Mon Feb 25, 2008 10:29 pm
Sorted, thanks Paul.
