Airbag light came on this morning when the car was started.
Wasn't on last night.
Why has it come on when it aint gone anywhere?
Whats it likley to be?
How can I reset it?
TIA
Airbag Light -HELP!!!!
RE: Airbag Light -HELP!!!!
I think you will need to check the fault codes using VAG-COM or similar.
Blue_Thunder
- Top Gear
Do a search on here. Very common issue.
Will be a dodgy connection under the seat probably, very common.
Normally easily fixed with a bit of wire waggling/terminal cleaning but unfortunately code cannot be cleared without a reset tool such as Vag-Com or various other scanners.
Sure someone on here will be happy to sort it for you - I am but I live in Cambridge.
- SonicDeathMonkey
Happened to be a loose connection under my passenger seat
tartan_rob
Tighten up connection and spray with WD40 etc., I found that helped no end.
2017 Kawasaki Z1000
2014 RS6
2014 S1
2014 RS6
2014 S1
Sorted, thanks Paul.
Users browsing this forum: Majestic-12 [Bot] and 101 guests
