Help with fault codes after Fault test....
Just used my Vag-com for the 1st time, run a for auto-scan and it came up with these faults....
5 Faults Found:
18030 - Engine Coolant Temp Signal: Implausible Signal
P1622 - 35-10 - - - Intermittent
17536 - Fuel Trim; Bank 1 (Mult): System too Lean
P1128 - 35-00 - -
17538 - Fuel Trim; Bank 2 (Mult): System too Lean
P1130 - 35-00 - -
P1128 - 35-00 - -
P1130 - 35-00 - -
Readiness: 0000 0000
Wednesday,11,July,2007,14:29:59:05380
VAG-COM Version: Release 704.1
Address 35: Centr. Locks
Control Module Part Number: 8D0 862 257 E
Component and/or Version: CV-Pump, Alarm, RC D13
Software Coding: 13166
Work Shop Code: WSC 06325
3 Faults Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00955 - Key 1
09-00 - Adaptation Limit Surpassed
01134 - Alarm Horn (H12)
49-00 - No Communications
What do they mean and how can i fix them ??
Any tips for using Vag-com ??
5 Faults Found:
P1128 - 35-00 - -
P1130 - 35-00 - -
P1128 - 35-00 - -
P1130 - 35-00 - -
3 Faults Found:
35-00 - -
00955 - Key 1
- ChipHazzard
RE: Help with fault codes after Fault test....
Adam,
The central locking codes can be cleared and I would consider getting a new alarm sounder, The engine codes relating to the system too lean would IMO indicate a dead MAF and not sure about the coolant temp one but if it's the sensor I think it is I would get it changed out for the later blue one iirc which is the after run pump mod
but I could be wrong and will stand corrected by some of our more knowledgable fellow drivers
HTH
Mike
HTH
Mike
FL Noggy S4 Avant
Kwack ZX7R & DRZ400 supermoto
BTW, the engine wasn't running when i did the test.... Nor was the ignition switched on
Yeah, it looks like a dead MAF.... peak reading was 107 today.... way low.
Ordered a new one, should be here tomo or friday
- shineydave
alarm - no communication is a knackered siren, probably the back up batteries have failed, new siren required or try to clag a seperate NiMH battery pack on the outside of the sounder to provide the back up power. you won't have any sound from the siren.
the others are fairly normal, i think the key 1 - adaption limit surpassed is because you haven't used the spare key for a while, pretty normal really
Thanks all
Do you happen to know where the siren is ?
- ChipHazzard
the sounder is in the drivers side cubby hole in the boot
FL Noggy S4 Avant
- shineydave
pull the trim off the right hand side of the boot, there's a well down the side behind the wheel arch, siren is bolted to the boot floor just under the rear light
The coolant sensor is also a 'known' weak part.
2001 Silver S4 Avant
i had to do this on mine after gavster hooked me up with vagcom, my temp needle would occasionally drop off as well - it should be a 4 pin sensor marked "coolant temp sender f18/f54" on the pic. i picked up the blue sensor for the afterun pump too and did both while i was there. mine was well crusty and an arse to pull out once the retaining clip was slid out.
'00 Nogaro S4 Avant
'88 Oak Green Mk2 Golf GTI
I know it as the G2/G62 sensor. Not sure why it is shown on that page as F18/F54.
Right, i've just changed my MAF and them 1st codes have cleared.
But i've now got this code....
Saturday,14,July,2007,12:55:20:05380
Address 01: Engine
Control Module Part Number: 8D0 907 551 D
Component and/or Version: 2.7l V6/5VT G 0002
Software Coding: 05711
Work Shop Code: WSC 00134
1 Fault Found:
17965 - Charge Pressure Control: Positive Deviation
P1557 - 35-00 - -
What does it mean ??
Address 01: Engine
1 Fault Found:
P1557 - 35-00 - -
- shineydave
that's prolly a result of the damaged TBB
