Help with fault codes after Fault test....
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
AdamS4
Post by AdamS4 » Wed Jul 11, 2007 2:49 pm
Just used my Vag-com for the 1st time, run a for auto-scan and it came up with these faults....
5 Faults Found:
18030 - Engine Coolant Temp Signal: Implausible Signal
P1622 - 35-10 - - - Intermittent
17536 - Fuel Trim; Bank 1 (Mult): System too Lean
P1128 - 35-00 - -
17538 - Fuel Trim; Bank 2 (Mult): System too Lean
P1130 - 35-00 - -
P1128 - 35-00 - -
P1130 - 35-00 - -
Readiness: 0000 0000
Wednesday,11,July,2007,14:29:59:05380
VAG-COM Version: Release 704.1
Address 35: Centr. Locks
Control Module Part Number: 8D0 862 257 E
Component and/or Version: CV-Pump, Alarm, RC D13
Software Coding: 13166
Work Shop Code: WSC 06325
3 Faults Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00955 - Key 1
09-00 - Adaptation Limit Surpassed
01134 - Alarm Horn (H12)
49-00 - No Communications
What do they mean and how can i fix them ??
Any tips for using Vag-com ??
ChipHazzard
RE: Help with fault codes after Fault test....
Post by ChipHazzard » Wed Jul 11, 2007 2:54 pm
Adam,
The central locking codes can be cleared and I would consider getting a new alarm sounder, The engine codes relating to the system too lean would IMO indicate a dead MAF and not sure about the coolant temp one but if it's the sensor I think it is I would get it changed out for the later blue one iirc which is the after run pump mod
but I could be wrong and will stand corrected by some of our more knowledgable fellow drivers
HTH
Mike
FL Noggy S4 Avant
Kwack ZX7R & DRZ400 supermoto
AdamS4
Post by AdamS4 » Wed Jul 11, 2007 3:00 pm
BTW, the engine wasn't running when i did the test.... Nor was the ignition switched on
AdamS4
Post by AdamS4 » Wed Jul 11, 2007 6:48 pm
Yeah, it looks like a dead MAF.... peak reading was 107 today.... way low.
Ordered a new one, should be here tomo or friday
shineydave
Post by shineydave » Wed Jul 11, 2007 7:10 pm
alarm - no communication is a knackered siren, probably the back up batteries have failed, new siren required or try to clag a seperate NiMH battery pack on the outside of the sounder to provide the back up power. you won't have any sound from the siren.
the others are fairly normal, i think the key 1 - adaption limit surpassed is because you haven't used the spare key for a while, pretty normal really
AdamS4
Post by AdamS4 » Wed Jul 11, 2007 7:19 pm
Thanks all :D
Do you happen to know where the siren is ?
ChipHazzard
Post by ChipHazzard » Wed Jul 11, 2007 7:51 pm
the sounder is in the drivers side cubby hole in the boot
FL Noggy S4 Avant
shineydave
Post by shineydave » Wed Jul 11, 2007 11:44 pm
pull the trim off the right hand side of the boot, there's a well down the side behind the wheel arch, siren is bolted to the boot floor just under the rear light
Dippy
Post by Dippy » Thu Jul 12, 2007 1:24 pm
The coolant sensor is also a 'known' weak part.
2001 Silver S4 Avant
AdamS4
Post by AdamS4 » Thu Jul 12, 2007 2:10 pm
Which one would it be ??
GHH
Post by GHH » Thu Jul 12, 2007 2:30 pm
i had to do this on mine after gavster hooked me up with vagcom, my temp needle would occasionally drop off as well - it should be a 4 pin sensor marked "coolant temp sender f18/f54" on the pic. i picked up the blue sensor for the afterun pump too and did both while i was there. mine was well crusty and an arse to pull out once the retaining clip was slid out.
'00 Nogaro S4 Avant
'88 Oak Green Mk2 Golf GTI
Dippy
Post by Dippy » Fri Jul 13, 2007 2:48 pm
I know it as the G2/G62 sensor. Not sure why it is shown on that page as F18/F54.
AdamS4
Post by AdamS4 » Sat Jul 14, 2007 12:56 pm
Right, i've just changed my MAF and them 1st codes have cleared.
But i've now got this code....
Saturday,14,July,2007,12:55:20:05380
Address 01: Engine
Control Module Part Number: 8D0 907 551 D
Component and/or Version: 2.7l V6/5VT G 0002
Software Coding: 05711
Work Shop Code: WSC 00134
1 Fault Found:
17965 - Charge Pressure Control: Positive Deviation
P1557 - 35-00 - -
What does it mean ??
Philws4
Post by Philws4 » Sat Jul 14, 2007 3:06 pm
B5 S4
shineydave
Post by shineydave » Sat Jul 14, 2007 4:42 pm
that's prolly a result of the damaged TBB
Return to “DTC / VCDS”
