Speeds in gears
Speeds in gears
Will someone post the speeds in gears per 1000 rpm Iv'e seen them somewhere but can't find them I think 6th is 24.9 ???????
JOHN
JOHN
RE: Speeds in gears
Don't know if this helps -
Gear ratios:
1st 3.667
2nd 2.050
3rd 1.462
4th 1.133
5th 0.919
6th 0,778
Reverse 3.333
Final drive ratio 3.889
Gear ratios:
1st 3.667
2nd 2.050
3rd 1.462
4th 1.133
5th 0.919
6th 0,778
Reverse 3.333
B8 A4 Avant quattro
Suzuki GSXR1000 (Track bike)
B6 S4 (AMD Stage 3) - GONE
8N TT (APR/AMD/MTM) - GONE
RE: Speeds in gears
Hi Scooty, it would help if I had a degree in maths.
RE: Speeds in gears
hehehe Don't ask me. I just copied out a pdf!!
All I know is they dyno's in the ration closest to 1:1 i.e. 5th in this case.
It also means you can go faster in reverse than in first!
B8 A4 Avant quattro
RE: Speeds in gears
Hi all I found them for anyone who's interested
1st=38
2nd=68
3rd=96
4th=123
5th=152
6th=155?
1st=38
2nd=68
3rd=96
4th=123
5th=152
6th=155?
Last one dead's a sissy.
RE: Speeds in gears
Theoretical, stated somewhere or having you been banging it in to the limiter?
p.s. 6th is at least 165mph
B8 A4 Avant quattro
RE: Speeds in gears
Taken from a road test comparison with M3 so might not be right. They do a BHP per ton and the maths in that 'aint right so who knows. Yes I have hit the limiter a few times it comes in at 7500. Even my wife has hit it in 1st and 2nd. I think its 'cause the thing is so smoooooooooooooth you can't tell it's reving.
RE: Speeds in gears
Always hit the thing in 1st - hit it in 3rd a few times too!!
Maserati GranTurismo GTS Auto, S3 Sportback, TT2 3.2 Roadster, Disco3 for the heavy stuff.
tartan_rob
RE: Speeds in gears
From the gear ratios, you can work out %age turns of wheels to engine revs, work of the circumference of the wheels * tyre size and therefore theoretical max speeds and mph/1000k by doing the "simple" arithmetic....
Not that I give a <beep>, was just throwing my 2pence in.
Anyone know how much quicker or slower the B6 in std guise is compared to the B5 with a stage1 on it? No idea how quick my motor is (B5) but I change my "Y's" frequently and almost always run into the car in front without trying....
2017 Kawasaki Z1000
2014 RS6
2014 S1
2014 RS6
2014 S1
