Speeds in gears
Speeds in gears
Will someone post the speeds in gears per 1000 rpm Iv'e seen them somewhere but can't find them I think 6th is 24.9 ???????
JOHN
JOHN
RE: Speeds in gears
Don't know if this helps -
Gear ratios:
1st 3.667
2nd 2.050
3rd 1.462
4th 1.133
5th 0.919
6th 0,778
Reverse 3.333
Final drive ratio 3.889
Gear ratios:
1st 3.667
2nd 2.050
3rd 1.462
4th 1.133
5th 0.919
6th 0,778
Reverse 3.333
B8 A4 Avant quattro
Honda CBR1100XX Super Blackbird
Suzuki GSXR1000 (Track bike)
B6 S4 (AMD Stage 3) - GONE
8N TT (APR/AMD/MTM) - GONE
RE: Speeds in gears
Hi Scooty, it would help if I had a degree in maths.
RE: Speeds in gears
hehehe Don't ask me. I just copied out a pdf!!
All I know is they dyno's in the ration closest to 1:1 i.e. 5th in this case.
It also means you can go faster in reverse than in first!
B8 A4 Avant quattro
RE: Speeds in gears
Hi all I found them for anyone who's interested
1st=38
2nd=68
3rd=96
4th=123
5th=152
6th=155?
1st=38
2nd=68
3rd=96
4th=123
5th=152
6th=155?
Last one dead's a sissy.
RE: Speeds in gears
Theoretical, stated somewhere or having you been banging it in to the limiter?
p.s. 6th is at least 165mph
B8 A4 Avant quattro
RE: Speeds in gears
Taken from a road test comparison with M3 so might not be right. They do a BHP per ton and the maths in that 'aint right so who knows. Yes I have hit the limiter a few times it comes in at 7500. Even my wife has hit it in 1st and 2nd. I think its 'cause the thing is so smoooooooooooooth you can't tell it's reving.
RE: Speeds in gears
Always hit the thing in 1st - hit it in 3rd a few times too!!
Maserati GranTurismo GTS Auto, S3 Sportback, TT2 3.2 Roadster, Disco3 for the heavy stuff.
tartan_rob
RE: Speeds in gears
From the gear ratios, you can work out %age turns of wheels to engine revs, work of the circumference of the wheels * tyre size and therefore theoretical max speeds and mph/1000k by doing the "simple" arithmetic....
Not that I give a <beep>, was just throwing my 2pence in.
Anyone know how much quicker or slower the B6 in std guise is compared to the B5 with a stage1 on it? No idea how quick my motor is (B5) but I change my "Y's" frequently and almost always run into the car in front without trying....
2017 Kawasaki Z1000
2014 RS6
2014 S1
2014 RS6
2014 S1
