Air lowering kit
Zeebuilder
Air lowering kit
Post by Zeebuilder » Sat Mar 19, 2016 8:26 am
Hi,
Looking through eBay and came across theese air lowering kits for cars with air. I know it's been talked about trying to lower with VCdS without much luck but I was wondering if anyone has used or had experience with this kit??
Paulm
Re: Air lowering kit
Post by Paulm » Sat Mar 19, 2016 11:09 am
Cant get into the secret menu on the FL RS6. I have tried loads but stuck. Searched Google for hours but there seems to be no solution for now.
That's what I am going to use.
BMW 540i
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
911 Turbo Remapped. Hated it
RS6 V10 700BHP crazy
D8vil
Post by D8vil » Sat Mar 19, 2016 5:13 pm
I fitted these to a q7 and worked
feeltheburn
Post by feeltheburn » Sat Mar 19, 2016 8:38 pm
I understood that Lowering with VCDS does not require access to the hidden menu? I guess it is differnet on a FL?
RS6 C7 (2014), Daytona Pearl, 21" Titanium, On Air, LEDs, Sports Exhaust, Dynamic Steering, Red Calipers, ACC, Top View, Connect, Tints, Rear Side Airbags, Rear heated seats; MP4S
Paulm
Post by Paulm » Sat Mar 19, 2016 9:05 pm
feeltheburn wrote:I understood that Lowering with VCDS does not require access to the hidden menu? I guess it is differnet on a FL?
Well yes and no. You can lower it a fraction but the problem is when above 35mph ( or there about) the car goes lower Adair if in dynamic and triggers an error as its too low. You need the menu to turn that feature off
BMW 540i
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
feeltheburn
Post by feeltheburn » Sat Mar 19, 2016 9:30 pm
Is the error unique to the FL? I have "a friend" who lowered by 17mm and has had no issues on a Pre FL.
Zeebuilder
Post by Zeebuilder » Sat Mar 19, 2016 9:33 pm
D8vil wrote:I fitted these to a q7 and worked
So would you say these ate legit? Are they easy to fit?
Post by MikeFish » Sat Mar 19, 2016 9:41 pm
feeltheburn wrote:Is the error unique to the FL? I have "a friend" who lowered by 17mm and has had no issues on a Pre FL.
Yes, the security code to access the module is alreayd known for the pre-FL cars. The FL has a different code which is still unknown.
feeltheburn
Post by feeltheburn » Sun Mar 20, 2016 1:32 pm
When my "friend" lowered his there was no need to access the hidden menu, all the changes were done in VCDS. Above circa 35mph there is no warning on the pre FL. So is the "too low" alert unique to the FL?
I believe that my "friend" lowered by 15mm all round not the full 17mm as I said before.
Paulm
Post by Paulm » Sun Mar 20, 2016 11:44 pm
feeltheburn wrote:So is the "too low" alert unique to the FL?
Sounds like it. I will lower mine this time home and report back. I did not bother because of what I read.
BMW 540i
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
Users browsing this forum: No registered users and 65 guests
