Looking through eBay and came across theese air lowering kits for cars with air. I know it's been talked about trying to lower with VCdS without much luck but I was wondering if anyone has used or had experience with this kit??
feeltheburn wrote:I understood that Lowering with VCDS does not require access to the hidden menu? I guess it is differnet on a FL?
So would you say these ate legit? Are they easy to fit?D8vil wrote:I fitted these to a q7 and worked
Yes, the security code to access the module is alreayd known for the pre-FL cars. The FL has a different code which is still unknown.feeltheburn wrote:Is the error unique to the FL? I have "a friend" who lowered by 17mm and has had no issues on a Pre FL.
Sounds like it. I will lower mine this time home and report back. I did not bother because of what I read.feeltheburn wrote:So is the "too low" alert unique to the FL?
I believe that my "friend" lowered by 15mm all round not the full 17mm as I said before.
