Hello all
I've just brought this, loaded it onto my PCs and am ready the use. Do I simply plug it it, turn ignition on (I don't believe the car has to be running?) and click Autoscan to scan if I've any faults?
Cheers,
Advice with VCDS
Re: Advice with VCDS
Yup. Then delete any errors, take a drive and re-scan. Great bit of kit as long as you don't start scanning every week and give yourself high blood pressure.
Before you scan press the brake pedal once or you'll get a spurious brake system error.
I usually turn the RNS off and HVAC too (fan to zero speed).
Is this a genuine full-price lead? If not you'll only have limited functionality, no autoscan, and will have to go into control units individually to find and clear errors.
Noted ta.
Yep, genuine stuff - I get the Autoscan option.
- RossDagley
- Top Gear
Odd. Never had this on any car I've scanned. What car have you experienced this on?HPsauce wrote:Before you scan press the brake pedal once or you'll get a spurious brake system error.![]()
Previously:
Previously:
Maybe it's only on older ones? Does it on any D2.
- RossDagley
- Top Gear
That might be it - I've done a few S3's (8P's) and B7's, along with a C6 and B8. Perhaps as you say it's older cars. Cheers - interesting and useful to remember!HPsauce wrote:Maybe it's only on older ones? Does it on any D2.
Previously:
Previously:
Can't recall the error, but you just press the brake pedal once and it goes away. It's quite confusing if you see it because it's not obvious what it means.
Users browsing this forum: No registered users and 143 guests
