Advice with VCDS
Fatneck73
Advice with VCDS
Post by Fatneck73 » Sat Nov 07, 2015 11:50 am
Hello all
I've just brought this, loaded it onto my PCs and am ready the use. Do I simply plug it it, turn ignition on (I don't believe the car has to be running?) and click Autoscan to scan if I've any faults?
Cheers,
Re: Advice with VCDS
Post by chunky79 » Sat Nov 07, 2015 12:00 pm
Yup. Then delete any errors, take a drive and re-scan. Great bit of kit as long as you don't start scanning every week and give yourself high blood pressure.
HPsauce
Post by HPsauce » Sat Nov 07, 2015 12:28 pm
Before you scan press the brake pedal once or you'll get a spurious brake system error. :wink:
I usually turn the RNS off and HVAC too (fan to zero speed).
Is this a genuine full-price lead? If not you'll only have limited functionality, no autoscan, and will have to go into control units individually to find and clear errors.
Fatneck73
Post by Fatneck73 » Sat Nov 07, 2015 12:40 pm
Noted ta.
Yep, genuine stuff - I get the Autoscan option.
RossDagley
Post by RossDagley » Sat Nov 07, 2015 3:42 pm
HPsauce wrote:Before you scan press the brake pedal once or you'll get a spurious brake system error. :wink:
Odd. Never had this on any car I've scanned. What car have you experienced this on?
Previously:
HPsauce
Post by HPsauce » Sat Nov 07, 2015 4:10 pm
Maybe it's only on older ones? Does it on any D2.
RossDagley
Post by RossDagley » Sat Nov 07, 2015 6:25 pm
HPsauce wrote:Maybe it's only on older ones? Does it on any D2.
That might be it - I've done a few S3's (8P's) and B7's, along with a C6 and B8. Perhaps as you say it's older cars. Cheers - interesting and useful to remember!
Previously:
HPsauce
Post by HPsauce » Sat Nov 07, 2015 6:53 pm
Can't recall the error, but you just press the brake pedal once and it goes away. It's quite confusing if you see it because it's not obvious what it means.
Return to “General Car Chat”
Users browsing this forum: No registered users and 142 guests
