Homelink
4.2 V8 32v FSI - 444 bhp
RossDagley
Homelink
Post by RossDagley » Fri Jul 17, 2015 4:30 pm
OK I give up - I simply can't get it to work with my controller for my roller shutter door.
It pairs properly (at least it tells me it has) with the three indicator blinks, but then the button I paired to simply does nothing. Repeated presses, long presses, facing the garage, facing away from the garage, one trouser leg rolled up, nipple exposed, nothing.
Anyone else had any issues or do I need to change my roller door opener? If so, to what? Happy to change if the homelink will then work!
Previously:
Afsimba
Re: Homelink
Post by Afsimba » Fri Jul 17, 2015 4:39 pm
Cover your work !
Can't get mine to work either all sorts of attempts !
And in same boat gonna change controller box or whole new door too :audibash:
doodlebug
Re: Homelink
Post by doodlebug » Fri Jul 17, 2015 6:27 pm
You need to check which version of the hone link kit the car has and whether it runs the frequency of your door controller. Often that is the issue.
RossDagley
Re: Homelink
Post by RossDagley » Fri Jul 17, 2015 9:03 pm
It's 433mhz the same as my remote. It says it's learnt the code, that's the frustrating thing!
Previously:
doodlebug
Homelink
Post by doodlebug » Fri Jul 17, 2015 9:05 pm
OK, so have you done the extra step to manage the changing sync?
http://www.homelink.com/program/instruc ... /ukenglish
Brooner
Re: Homelink
Post by Brooner » Sat Jul 18, 2015 9:24 am
I had this issue every thing says its paired but does not work then i found out that the homelink and the Audi unit need another receiver http://www.shopssl.de/epages/es10567317 ... ts/PR433-3
this sorted my Hormann operner out hope this helps
Snotsicle
Re: Homelink
Post by Snotsicle » Sat Jul 18, 2015 10:29 pm
Brooner wrote:I had this issue every thing says its paired but does not work then i found out that the homelink and the Audi unit need another receiver http://www.shopssl.de/epages/es10567317 ... ts/PR433-3
That's what I ended up doing. It works fine.
Current: Daytona Grey '14 RS4 Avant +most options
Previous Audis:
Phantom Black '07 B7 S4 Avant Tip
Akoya Silver '03 B6 A4 Avant 3.0 Quattro Tip
Ming Blue '99 B5 A4 Avant 2.8 Quattro Tip
Laser Red '97 8L A3 3dr 1.8T
Assorted junk too embarrassing to list
Users browsing this forum: JamesBaby, Quinten and 90 guests
