OK I give up - I simply can't get it to work with my controller for my roller shutter door.
It pairs properly (at least it tells me it has) with the three indicator blinks, but then the button I paired to simply does nothing. Repeated presses, long presses, facing the garage, facing away from the garage, one trouser leg rolled up, nipple exposed, nothing.
Anyone else had any issues or do I need to change my roller door opener? If so, to what? Happy to change if the homelink will then work!
Homelink
- RossDagley
- Top Gear
Homelink
Previously:
Previously:
Re: Homelink
Cover your work !
Can't get mine to work either all sorts of attempts !
And in same boat gonna change controller box or whole new door too
Re: Homelink
You need to check which version of the hone link kit the car has and whether it runs the frequency of your door controller. Often that is the issue.
- RossDagley
- Top Gear
Re: Homelink
It's 433mhz the same as my remote. It says it's learnt the code, that's the frustrating thing!
Previously:
Previously:
Homelink
OK, so have you done the extra step to manage the changing sync?
http://www.homelink.com/program/instruc ... /ukenglish
Re: Homelink
I had this issue every thing says its paired but does not work then i found out that the homelink and the Audi unit need another receiver http://www.shopssl.de/epages/es10567317 ... ts/PR433-3
this sorted my Hormann operner out hope this helps
2018 B9 RS4 Navarra Blue
2013 B8 RS4 Sepang Blue
2007 B7 RS4 Avant Sprint Blue
2001 B5 RS4 Nogaro Blue
1993 B4 S2 Avant laser Red
Re: Homelink
That's what I ended up doing. It works fine.Brooner wrote:I had this issue every thing says its paired but does not work then i found out that the homelink and the Audi unit need another receiver http://www.shopssl.de/epages/es10567317 ... ts/PR433-3
Current: Daytona Grey '14 RS4 Avant +most options
Previous Audis:
Phantom Black '07 B7 S4 Avant Tip
Akoya Silver '03 B6 A4 Avant 3.0 Quattro Tip
Ming Blue '99 B5 A4 Avant 2.8 Quattro Tip
Laser Red '97 8L A3 3dr 1.8T
Assorted junk too embarrassing to list
Previous Audis:
Users browsing this forum: No registered users and 92 guests
