RS6 C7 | 800+ BHP
dasquade
Re: RS6 C7 | 800+ BHP
Post by dasquade » Mon Feb 05, 2018 5:20 am
Maybe some more infra red temp data (keep in mind the ambient temps where 7°C lower then my previous log and i didn't pushed it that hard!).
Unshielded Shielded
Ambient air: 11°C 4°C
Oil temp: 102°C 94°C
Cats: 390°C 290°C (that one kinda gives away i didn't floored it tooooo much)
Manifolds: 300°C 80-90°C :) (the passengiers side is still half shielded and the unshielded side read 210°C)
Turbo: hotside 260°C / cold 90°C 146°C (fully shielded) 120°C (half shielded) cold side 60°C - 65°C
Intake tubes (heat wrapped): 75°C 70°C (again that side is atm still only half shielded)
Airfilter: 50°C 34°C (this time the filter and box had same temps)
Coolant reservoir: 80°C 68°C (again maybe indication i didn't floored it that much and lower ambient temps cooled things better)
Metal air-water charger: 55°C 60°C
Kinda shows it is hard to data log on different days etc, but kinda happy to see the fully shielded manifold kept a lot of heat inside as surface temps dropped by 1/3 (give and take as i didn't floored it that much). Just hope the hot side of turbo's can handle the insulation under load (as those turn boiling 'red') but the insulation can handle up to 982°C continuous/1204°C intermittent.
*sorry for the confusion, i'm indeed the insulation guy and not the water/meth guy :p but very curious about the install (well atm water only for me) as it makes me want to do the water injection aswell seeing those IAT's :). Personally i rather want to use the windshield reservoir as water injection tank (since it has a build in 'low level' warning and hook up the windshield to other reservoir and pomp (do not really care if that runs out of water :p).
*Crap, i had added spaces between the data to make it more visible between unshielded and shielded but apperently the txt code doesn't apply it when posted. OHwell :).
DXB_RS6
Post by DXB_RS6 » Mon Feb 05, 2018 6:42 am
finance-nick wrote:cant see what im looking at, were they 75c before, then went down to 25c with water on?
-like to know is what increase in power does it made?
-where did they fit the jets? any chance of photo’s?
Yes, a major drop in temps. I'll get some better images for the logs later.
Sent from my SM-G955F using Tapatalk
finance-nick
Post by finance-nick » Mon Feb 05, 2018 10:28 am
MikeFish wrote:
Mon Feb 05, 2018 1:41 am
finance-nick wrote:
Mon Feb 05, 2018 1:06 am
dasquade wrote:
Mon Feb 05, 2018 12:30 am
Well bit hard to take pictures as everything is soooooo close and packed :).
I'm using obdeleven, bit simular as VCDS but for android. Pretty cheap app/dongle but always carry it in the car.
You can do almost anything you can do with VCDS, comes with a few 'one click' settings and you can live data record stuff.
Ahh ok, so can you verbally describe where your meth injectors are fitted?
Wrong dude. This guy is insulating, the other guy has the aquamist.
Good point
finance-nick
Post by finance-nick » Mon Feb 05, 2018 10:30 am
Can i ask where the injectors were fitted, also did it make more power - feel quicker?
dasquade
Post by dasquade » Mon Feb 05, 2018 11:40 am
x2 :)
DXB_RS6
Post by DXB_RS6 » Mon Feb 05, 2018 5:41 pm
Fitted in the intake Manifold.
It is faster, feels more responsive now especially when shifting. I'll Dyno it when I get a chance.
You hear the noise of the spray from the boot when it activates, sounds good now but would probably become annoying after some time.
My recommended mix was 75/25 Meth.
finance-nick
Post by finance-nick » Mon Feb 05, 2018 6:42 pm
Brilliant thanks, but just to clarify - do you mean the manifold after the chargecooler?
this will basically be located at the bottom of the engine out of site?
dasquade
Post by dasquade » Mon Feb 05, 2018 6:59 pm
I suppose they drilled indeed in the front of the plastic air manifold just behind the radiator or from the top, very curious as that means a difference between removing charge cooler and radiator :s. More specific info is much appreciated :).
As this might be my next step aswell...
Meanwhile wrapped the passengier manifold and top side of the turbos. Not sure about the underside of the turbos...almost impossible to get by and bit worried if it aint a decent fitting and pressed against the surface it will create heat pockets and do more harm then it is worth.
All bit risky buisness (but in wirst case i'm in for turbo upgrade).
Next might be the downpipes....
finance-nick
Post by finance-nick » Mon Feb 05, 2018 7:46 pm
FANTASTIC JOB my friend, this will really work well once perfect, here are my points of view:
1) I don't think the heat sheild touching the turbo will matter, and is much better to be shielded and touching, than not shielded and not touching
2) you have used the wong stuff to wrap your turbo intakes, thats heat wrap to keep heat in NOT keep heat out, you need these for the intakes: http://www.ebay.co.uk/itm/172887065041
dasquade
Post by dasquade » Mon Feb 05, 2018 8:13 pm
Cheers :)...hm that you mention, totally wrong material (lets heat through instead of blocking)!
Will remove it, leave stock or check for better material.
Meanwhile did one downpipe. Only +-30cm from trubo downwards, witch is the place were the tunnel starts to open up again and hopefully most heat finds its way outside...
Still gonna do the other downpipe and call it a night :).
Hopefully it was worth something...
finance-nick
Post by finance-nick » Mon Feb 05, 2018 8:18 pm
DXB_RS6
Post by DXB_RS6 » Mon Feb 05, 2018 8:51 pm
Have you got these?
How many do I order?
Easy to fix?
dasquade
Post by dasquade » Mon Feb 05, 2018 9:52 pm
Considering the manifolds/turbos/downpipes shielding a wrap :).
Sadely run out of material to cover the underside of the turbo's, not sure if that is a bad thing or not (will be difficult to do it anyway) but should be better then nothing i think?
Will try to log some more over the following days....
finance-nick
Post by finance-nick » Mon Feb 05, 2018 9:54 pm
brilliant job !!!!!!!
DXB_RS6
Post by DXB_RS6 » Tue Feb 06, 2018 5:20 am
It is after the intercooler on the plastic behind the radiator. ImageImage
Users browsing this forum: No registered users and 112 guests
