Clunking noise ...
Re: Clunking noise ...
...but i dont understand why theres play in the in-out direction....that has nothing to do with a bearing is it? if a bearing is kaput there should be play in opposite direction...?
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
Yellow Koni's
Wheel was the play when it was all bolted up? It doesn't surprise me that there's axial play. Some cars have nothing to hold the flange in since when everything is assembled the drive shaft limits how far the flange can come out.
...the part of the driveshaft connected to the flange axle can move axial for several cm...
Yellow Koni's
Yellow Koni's
ive just shot a short video clip of it, just a minute...
Yellow Koni's
Yellow Koni's
here you can see and hear the play, that sound is exactly what i hear while driving...
http://www.youtube.com/watch?v=Q7uC4PVs ... e=youtu.be
Yellow Koni's
Yellow Koni's
http://www.youtube.com/watch?v=FkV_pu98 ... e=youtu.bemavada wrote:...the part of the driveshaft connected to the flange axle can move axial for several cm...
Yellow Koni's
Yellow Koni's
Could it just be the inner cv joint isnt giving enough resistance after time, to eliminate the play? in other words, driveshaft gone...?
Yellow Koni's
Yellow Koni's
...ive heard from someone whos into these boxes its normal theres play like that...shoot me
ive send ZF an email to hear what they say about this,,,
Yellow Koni's
Yellow Koni's
Doesn't explain your grinding. Might be coming from somewhere else, of course.
i hope i get response from ZF soon before i get it all together again...
Yellow Koni's
Yellow Koni's
Don't hold your breath. Can you change the oil seal without removing the diff cover?
yeah thats easy...but i want to be 1000% sure that play is normal.
could try in the meantime a spare driveshaft (if i can find one...) to see if that works...
Yellow Koni's
Yellow Koni's
I think axial play is normal, but not in the perpendicular plane like the video you sent.
...what part of a broken drc shock makes clunking noises? i can check now its on a jack...
Yellow Koni's
Yellow Koni's
It isn't the shock - it's low pressure in the system has the valve system misbehaving. To check shocks simply look for evidence of leakage of hydraulic fluid
Users browsing this forum: No registered users and 112 guests
