Clunking noise ...
mavada
Re: Clunking noise ...
Post by mavada » Sun Jun 30, 2013 7:42 am
...but i dont understand why theres play in the in-out direction....that has nothing to do with a bearing is it? if a bearing is kaput there should be play in opposite direction...?
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
Post by Shoppinit » Sun Jun 30, 2013 7:57 am
Wheel was the play when it was all bolted up? It doesn't surprise me that there's axial play. Some cars have nothing to hold the flange in since when everything is assembled the drive shaft limits how far the flange can come out.
mavada
Post by mavada » Sun Jun 30, 2013 8:01 am
...the part of the driveshaft connected to the flange axle can move axial for several cm...
Yellow Koni's
mavada
Post by mavada » Sun Jun 30, 2013 8:10 am
ive just shot a short video clip of it, just a minute...
Yellow Koni's
mavada
Post by mavada » Sun Jun 30, 2013 8:21 am
here you can see and hear the play, that sound is exactly what i hear while driving...
http://www.youtube.com/watch?v=Q7uC4PVs ... e=youtu.be
Yellow Koni's
mavada
Post by mavada » Sun Jun 30, 2013 8:37 am
mavada wrote:...the part of the driveshaft connected to the flange axle can move axial for several cm...
http://www.youtube.com/watch?v=FkV_pu98 ... e=youtu.be
Yellow Koni's
mavada
Post by mavada » Sun Jun 30, 2013 9:05 am
Could it just be the inner cv joint isnt giving enough resistance after time, to eliminate the play? in other words, driveshaft gone...?
Yellow Koni's
mavada
Post by mavada » Sun Jun 30, 2013 6:08 pm
...ive heard from someone whos into these boxes its normal theres play like that...shoot me :bash:
ive send ZF an email to hear what they say about this,,,
Yellow Koni's
Post by Shoppinit » Sun Jun 30, 2013 6:22 pm
Doesn't explain your grinding. Might be coming from somewhere else, of course. :)
mavada
Post by mavada » Sun Jun 30, 2013 6:51 pm
i hope i get response from ZF soon before i get it all together again...
Yellow Koni's
Post by Shoppinit » Sun Jun 30, 2013 7:00 pm
Don't hold your breath. Can you change the oil seal without removing the diff cover?
mavada
Post by mavada » Sun Jun 30, 2013 7:02 pm
yeah thats easy...but i want to be 1000% sure that play is normal.
could try in the meantime a spare driveshaft (if i can find one...) to see if that works...
Yellow Koni's
Post by Shoppinit » Sun Jun 30, 2013 7:09 pm
I think axial play is normal, but not in the perpendicular plane like the video you sent.
mavada
Post by mavada » Sun Jun 30, 2013 9:52 pm
...what part of a broken drc shock makes clunking noises? i can check now its on a jack...
Yellow Koni's
Daveperc
Post by Daveperc » Mon Jul 01, 2013 4:27 pm
It isn't the shock - it's low pressure in the system has the valve system misbehaving. To check shocks simply look for evidence of leakage of hydraulic fluid
Users browsing this forum: philS2 and 108 guests
