Gearbox Teardown & Refurbish - 6HP28A61
5.0 V10 50v biturbo - 571 bhp
RS_BROKE
Re: Gearbox Teardown & Refurbish - 6HP28A61
Post by RS_BROKE » Tue Dec 01, 2020 10:10 pm
Jim Haseltine wrote:
Mon Nov 30, 2020 10:20 pm
RS_BROKE wrote:
Mon Nov 30, 2020 3:09 pm
I’ve got proper torx se but this is external I just put a 9mm socket and it came off thanks anyway 👍
TX-sockets
Thanks 👍 I need to get set
RS_BROKE
Post by RS_BROKE » Tue Dec 01, 2020 10:47 pm
They are the female torx set you need for that if anyone wants to know but a 9mm socket works fine👍
RS_BROKE
Post by RS_BROKE » Tue Dec 01, 2020 10:48 pm
Above I said the mechatronic unit wouldn’t come out as I thought it was catching on selector I was wrong it was just stupid me left one bolt 😂
RS_BROKE
Post by RS_BROKE » Tue Dec 01, 2020 10:50 pm
As At said make sure not to scratch the mating surfaces I used some bubble wrap.
RS_BROKE
Post by RS_BROKE » Tue Dec 01, 2020 10:52 pm
Hmm the oil that was left after lifting the mechatronic out looks black and burnt clutches?
Next up clutches out then we will see!
RS_BROKE
Post by RS_BROKE » Fri Dec 04, 2020 10:39 pm
Double oil seal looks good
RS_BROKE
Post by RS_BROKE » Fri Dec 04, 2020 10:40 pm
These do look scored inside and the top
RS_BROKE
Post by RS_BROKE » Fri Dec 04, 2020 10:42 pm
These are all different sizes, this is starting from the opposite side to the front diff
RS_BROKE
Post by RS_BROKE » Fri Dec 04, 2020 10:43 pm
I used a little pick to get the rubber tubes out like the ones you use for oil filter seals works fine just be careful no to scratch the bores!
RS_BROKE
Post by RS_BROKE » Fri Dec 04, 2020 10:44 pm
My valve body seal number is also ao63
ATinOf
Post by ATinOf » Sun Dec 06, 2020 3:26 pm
RS_BROKE wrote:
Sun Nov 29, 2020 7:55 pm
Finally got the oil coolers off by making a t30 fit in a t25😎
Some of the ZF torx fittings are T27, thats prob why you stripped a few - not a common size but you can get them, I'd recommend the impact versions as they tend to last a bit longer
I did point this out I think in one of my posts, maybe I missed it, it was a bit of an epically long post!
ATinOf
Post by ATinOf » Sun Dec 06, 2020 3:35 pm
RS_BROKE wrote:
Sat Nov 28, 2020 8:04 pm
Transfer case magnet
The bearing in the transfer case seems to have lot of play when the output shaft is out maybe this is normal 🤔maybe At can comment on this.
Some play in that thrust bearing is normal with nothing pushing it together, did you check the axial play in the output shaft with a DTI before the strip down? The output shaft axial clearance is taken up by that round selective washer that nearly fell out in your prior post, dont lose it !!
welwynnick
Post by welwynnick » Sun Dec 06, 2020 3:47 pm
That double oil seal is probably responsible for most 6HP problems. It's a no-brainer to replace it, but watch out, there are two different sizes / heights.
Nick
RS_BROKE
Post by RS_BROKE » Mon Dec 07, 2020 7:56 pm
im waiting on a t27 now for the oil pump
RS_BROKE
Post by RS_BROKE » Mon Dec 07, 2020 8:02 pm
yes we did it was 0,2xx i have it written somewhere cant remember the exact reading, yes still have the washer, i have looked at another gearbox that we have sitting around which is also a zf6 quattro once taken off as the shaft is not there to "support sit in there"
Users browsing this forum: No registered users and 20 guests
