Flaps !
ROY
Re: Flaps !
Post by ROY » Wed Sep 26, 2012 10:59 pm
Jesus !!!!!!!!!
My carbon was almost identical, n/s 3rd cylinder back was the worst
Glad i removed my flaps :bigblink:
Whats involded with the rebuild how far you going - just fixing it or what ????
Might as well put pistons rings n shells in etc while its out ?????
Gone but not forgotten boohoo !!!
RS4 Sprint Blue Avant on Dyno after Carbon Clean http://youtu.be/7lsBbmmaDQc
rs4lee
Re: Flaps !
Post by rs4lee » Wed Sep 26, 2012 11:09 pm
ROY wrote:Jesus !!!!!!!!!
I think the customer is going to source a complete 2nd hand motor due to the cost of stripping the block down and repairing it (parts/labour)
although he may have to have it repaired if he can not source a motor !!
api330
Re: Flaps !
Post by api330 » Wed Sep 26, 2012 11:24 pm
Is there a link on how to remove these flaps I think maybe I should take them out,
ROY
Re: Flaps !
Post by ROY » Wed Sep 26, 2012 11:32 pm
Needs a block !!! Wow :shock:
Low mileage engine on ebay at the moment
http://www.ebay.co.uk/itm/Audi-RS4-Engi ... 3ccae43d4f
Re: Flaps !
Post by bam_bam » Thu Sep 27, 2012 7:37 am
Cheap for a reason. It looks as though it's been in a fire, then it got addicted to paint thinner and now lives in Stapleton Road, Bristol and it's sold its exhaust manifold for more paint thinner.
stu
Re: Flaps !
Post by stu » Thu Sep 27, 2012 9:09 am
That Ebay engine is worth a photo.
P14VLL
Re: Flaps !
Post by P14VLL » Thu Sep 27, 2012 9:19 am
What’s Audi UK doing about this problem or have they turned a blind eye to it? :audibash:
Do they recommend that they are removed? and replaced with these plugs?
Thanks,
Paul.
Dave_Hedgehog
Flaps !
Post by Dave_Hedgehog » Thu Sep 27, 2012 9:47 am
Are these flaps the same thing as the swirl valve that destroyed my first RS3s engine ?
ROY
Re: Flaps !
Post by ROY » Thu Sep 27, 2012 12:11 pm
That ebay engine looks a real dog :thumbsdown: when you blow the picture up
Re: Flaps !
Post by bam_bam » Thu Sep 27, 2012 12:51 pm
ROY wrote:That ebay engine looks a real dog :thumbsdown: when you blow the picture up
When you blow up the picture?!?!? It's hideous at any size. If that thing was on a 1st class postage stamp I wouldn't lick it.
aled_31
Re: Flaps !
Post by aled_31 » Thu Sep 27, 2012 7:09 pm
That ebay engine is from Keighley, West Yorkshire!!
Nuff Said :roll: :roll:
Current:
B9 RS4 Avant in Missano
1991 Mk2 Golf GTI 8v, Big Bumper in Oak Green
1960 VW Beetle 1200 (6 volt, 34hp!)
1999 Porsche Boxster 2.5
On Order:
B9.5 RS4 Avant in Daytona
Previous:
3 x B7 Avants in Sprint, Phantom and Daytona (Loved that car!!)
3 x B8 Avants in Daytona, Phantom and Ibis
2 x B9 Avants in Missano (x2), Daytona
1 x B8 S4 Avant in Sprint
OskiRs4
Re: Flaps !
Post by OskiRs4 » Thu Sep 27, 2012 10:23 pm
Could i ask how much is it to get the flap removed? does it affect running , and any good places in Essex who could do it? Thanks
stu
Re: Flaps !
Post by stu » Fri Sep 28, 2012 10:45 am
Hi Lee, would you mind clarifying a few things?
rs4lee wrote: [...]The only reason i am posting this is so others realise how much of a nusance these inlet manifold flaps are ,and that getting them removed could save you a massive repair bill when one goes through your engine.[...]
1- Was this engine ever opened prior to the incident?
2- What upgrades (if any) had been done physically or engine management/mapping?
The reason I ask these things is because I am surprised. I know very little myself about the RS4 engine bar what I have gleaned from this website over the last few years, and I am surprised that I have not read much this issue if it is as important as you consider it to be. I know flaps are taken off when porting and other times when the engine is opened, but I thought that was because the had a knack of failing when interfered with. You are a professional mechanic, I'm a novice and here to learn.
rs4lee wrote: [...]Plus once removed you can have the piece of mind knowing the little buggers cant cause any problems as most peoples cars are getting to the mileage were problems can occur.[...]
3- Is it really milage related?
4- Is it ok to generalise that all cars are at some imminent risk of flap failure?
Ultimately I'm just wondering if this truely is something that needs to be done to every car. I might be wrong, but you are inferring it is.
Anyone else want to throw in their two pennies?
Stu. :beerchug:
sonny
Flaps !
Post by sonny » Fri Sep 28, 2012 4:34 pm
Removing flaps improves airflow, however the circulation of the airflow around the valves will change.
Homogenous and stratified modes are what the flaps are designed to do . With them removed the air flow will be in homogenous mode, air tumbling around both sides of the valve head (stratified mode, one side of valve head).
When removed you may see an increase in MPG when stationary.
This is my understanding
api330
Re: Flaps !
Post by api330 » Fri Sep 28, 2012 6:09 pm
sonny wrote:Removing flaps improves airflow, however the circulation of the airflow around the valves will change.
Do you think removing the flaps may help with the carbon build up as it would change the way the fuel and air moves around the valves + do you know if theres a link or any info any where on how to remove them, Cheers
Users browsing this forum: Google [Bot] and 216 guests
