Vcds ordered
brn7y
Vcds ordered
Post by brn7y » Fri Jun 29, 2012 11:16 pm
Scatman wrote:Enable the rather subtle alarm blip when you lock the car
How?
brn7y
Vcds ordered
Post by brn7y » Fri Jun 29, 2012 11:17 pm
adsgreen wrote:Rns-e rs4 logo :)
Check logs / stored codes.
Cannot access rns-e
brn7y
Vcds ordered
Post by brn7y » Sat Jun 30, 2012 10:19 am
Still no joy?
PetrolDave
Re: Vcds ordered
Post by PetrolDave » Sat Jun 30, 2012 10:29 am
DALO wrote:I've just checked - it's in the coding of Module 17 - Instrument Cluster (J285)
Remove 16 from the 3rd & 4th digits and the "press clutch pedal to start engine" nanny reminder will vanish and you'll get the normal DIS display when the engine's off. In the coding guidance it's described as "+16 = clutch pedal switch operation in FIS display".
As standard the coding in mine was 0023418, so I changed it to 0007418, job done.
Thanks, will do that today!
PetrolDave
Re: Vcds ordered
Post by PetrolDave » Sat Jun 30, 2012 10:31 am
brn7y wrote:
PetrolDave wrote:Enabling window open/close on remote press (can also close sunroof on remote but not open it).
Enabling rear lights on when DRLs on.
Changing pitch and volume of parking aid so that difference in pitch between front and rear warnings is more obvious.
1 done
2 done
3 how?
See http://wiki.ross-tech.com/wiki/index.ph ... 8EC/8ED%29
PetrolDave
Re: Vcds ordered
Post by PetrolDave » Sat Jun 30, 2012 10:32 am
Cannot access rns-e
Are you using a dual K-line lead? The RNS-E is actually on the L(K2) line so if you use a single K-line lead or a CAN only lead you won't be able to access it.
If you are using a dual K-line lead, then the L(K2) line may not be connected to your RNS-E - is it a retrofitted one?
brn7y
Vcds ordered
Post by brn7y » Sat Jun 30, 2012 11:18 am
1 done
2 done
3 how?
done
brn7y
Vcds ordered
Post by brn7y » Sat Jun 30, 2012 11:19 am
This is great, just wish I could access the rns-e
brn7y
Vcds ordered
Post by brn7y » Sat Jun 30, 2012 11:20 am
Cannot access rns-e
it is the latest duel lead from Ross-Tech direct.
brn7y
Vcds ordered
Post by brn7y » Sat Jun 30, 2012 11:22 am
Not sure if retrofitted, we're they not all standard on uk cars?
adsgreen
Re: Vcds ordered
Post by adsgreen » Sat Jun 30, 2012 11:24 am
brn7y wrote:Not sure if retrofitted, we're they not all standard on uk cars?
nope.
brn7y
Vcds ordered
Post by brn7y » Sat Jun 30, 2012 11:54 am
Checked option code, factory fitted.
PetrolDave
Re: Vcds ordered
Post by PetrolDave » Sat Jun 30, 2012 2:58 pm
brn7y wrote:Checked option code, factory fitted.
Then you need to get someone to check the wiring - it will have been OK when it left the factory but looks like it's failed since then.
brn7y
Vcds ordered
Post by brn7y » Mon Jul 09, 2012 11:34 am
Fixed, was aftermarket iPod connection causing problems.
dave635
Re: Vcds ordered
Post by dave635 » Tue Jul 10, 2012 9:06 am
I just purchased VCDS from Ilexa (UK RossTech agent) & am having a similar problem, can't talk to the RNSE direct (module 37) or via the radio module.
Reading through the posts i see mention of a dual cable, the one I have only has one connector to fit the port under the dash. Where is the 2nd port ?
I also have an Ipod connection in the glovebox that is connected via the CD changer. Do I have the wrong cable or is the problem likely to be the Ipod conn ?
Thanks for any help,
Dave.
2007 RS4 Avant Silver (now sadly sold), 1989 BMW 635csi.
