How?Scatman wrote:Enable the rather subtle alarm blip when you lock the car
Vcds ordered
Vcds ordered
Vcds ordered
Cannot access rns-eadsgreen wrote:Rns-e rs4 logo
Check logs / stored codes.
Vcds ordered
Still no joy?
- PetrolDave
Re: Vcds ordered
Thanks, will do that today!DALO wrote:I've just checked - it's in the coding of Module 17 - Instrument Cluster (J285)
Remove 16 from the 3rd & 4th digits and the "press clutch pedal to start engine" nanny reminder will vanish and you'll get the normal DIS display when the engine's off. In the coding guidance it's described as "+16 = clutch pedal switch operation in FIS display".
As standard the coding in mine was 0023418, so I changed it to 0007418, job done.
- PetrolDave
Re: Vcds ordered
See http://wiki.ross-tech.com/wiki/index.ph ... 8EC/8ED%29brn7y wrote:1 donePetrolDave wrote:Enabling window open/close on remote press (can also close sunroof on remote but not open it).
Enabling rear lights on when DRLs on.
Changing pitch and volume of parking aid so that difference in pitch between front and rear warnings is more obvious.
2 done
3 how?
- PetrolDave
Re: Vcds ordered
Are you using a dual K-line lead? The RNS-E is actually on the L(K2) line so if you use a single K-line lead or a CAN only lead you won't be able to access it.brn7y wrote:Cannot access rns-eadsgreen wrote:Rns-e rs4 logo
If you are using a dual K-line lead, then the L(K2) line may not be connected to your RNS-E - is it a retrofitted one?
Vcds ordered
donePetrolDave wrote:See http://wiki.ross-tech.com/wiki/index.ph ... 8EC/8ED%29brn7y wrote:1 donePetrolDave wrote:Enabling window open/close on remote press (can also close sunroof on remote but not open it).
2 done
3 how?
Vcds ordered
This is great, just wish I could access the rns-e
Vcds ordered
it is the latest duel lead from Ross-Tech direct.PetrolDave wrote:Are you using a dual K-line lead? The RNS-E is actually on the L(K2) line so if you use a single K-line lead or a CAN only lead you won't be able to access it.brn7y wrote:Cannot access rns-eadsgreen wrote:Rns-e rs4 logo
Vcds ordered
Not sure if retrofitted, we're they not all standard on uk cars?
Re: Vcds ordered
nope.brn7y wrote:Not sure if retrofitted, we're they not all standard on uk cars?
Vcds ordered
Checked option code, factory fitted.
- PetrolDave
Re: Vcds ordered
Then you need to get someone to check the wiring - it will have been OK when it left the factory but looks like it's failed since then.brn7y wrote:Checked option code, factory fitted.
Vcds ordered
Fixed, was aftermarket iPod connection causing problems.
Re: Vcds ordered
I just purchased VCDS from Ilexa (UK RossTech agent) & am having a similar problem, can't talk to the RNSE direct (module 37) or via the radio module.
Reading through the posts i see mention of a dual cable, the one I have only has one connector to fit the port under the dash. Where is the 2nd port ?
I also have an Ipod connection in the glovebox that is connected via the CD changer. Do I have the wrong cable or is the problem likely to be the Ipod conn ?
Thanks for any help,
Dave.
Dave.
2007 RS4 Avant Silver (now sadly sold), 1989 BMW 635csi.
Users browsing this forum: No registered users and 114 guests
