Shortshifters
Bushy
Re: Shortshifters
Post by Bushy » Tue Jan 28, 2003 8:25 am
Bushy
I have a theory as to what has caused the problem you discribe, but I need to look at it to be certain.
Whatever the outcome, be it defect or incorrect instalation, I will replace it foc and if we can make the arrangements I will fit it into your car.
I don't know if I can do it on the 3rd, if not then I am sure I could do it at the rolling road meet on the 5th.
Karl
Superb Carl
I knew that you would, never doubted you mate. Service makes all the differnce these days, get your Tanoga shifts here - advertising/marketting mode off [img]images/graemlins/grin.gif[/img]
I see the bearing you useis in fact strong enough for the job, which was my initial thought on the subject, it is where the bolt goes through the aluminium shaft that it has worn, i suggest some sort of insert to stop wear.
But when you get it you can comment
Also i did not really realise your shift had 2 settings so when i get it fitted next time i will go for the 40 degree no the 30 degree
At the rolling road will be great mate
Can't beat a bit of boost!
Thorney
Location: Wherever the centre of the universe is, I'm about as far away from it as possible.
Re: Shortshifters
Post by Thorney » Tue Jan 28, 2003 9:41 am
If the Stat one is the same then I guess I'd better get AMD to have a look at it - prevention being better tahn cure after all.
Bushy - did the shifter cause the gearbox problem?
johneroberts
Re: Shortshifters
Post by johneroberts » Tue Jan 28, 2003 9:46 am
You ever seen him change gear [img]images/graemlins/grin.gif[/img]
Bushy the fastest change in the west [img]images/graemlins/grin.gif[/img]
Driving is believing
RS246 Founder
Bushy
Re: Shortshifters
Post by Bushy » Tue Jan 28, 2003 10:31 am
I dont think so
The play in the shift can only effect how each gear is selected
The gearbox problem was actually synchromesh on first/second gears failing, then ultimately breakin ginto pieces inside the box [img]images/graemlins/blush.gif[/img]
tanoga
Re: Shortshifters
Post by tanoga » Fri Jan 31, 2003 10:27 am
Bushy
I have today received your short shifter through the post.
It is with great pleasure [img]images/graemlins/biggrin3.gif[/img] that I detail my findings.
You are correct in your comments regarding the wear/play in the bottom linkage and I have to say that the design of it is an absolute piece of sh!te.
The only problem is the shifter that you have returned to me is NOT a Tanoga shifter, it is a UUC or Stratmosphere one. I cannot say which one as I have not seen either before.
I can bring the shifter with me on Monday and let you have it back, and at the same time show you a Tanoga shifter [img]images/graemlins/gotmesome.gif[/img]
Karl [img]images/graemlins/roflmao.gif[/img]
tanoga
Re: Shortshifters
Post by tanoga » Fri Jan 31, 2003 10:32 am
ps Bushy
I am not trying to mitigate your problem and I am always here to help out with your problem, but you got to see the funny side from my point of view
Karl
PhilT
RS246.com
Re: Shortshifters
Post by PhilT » Fri Jan 31, 2003 10:34 am
I thought it was funny [img]images/graemlins/roflmao.gif[/img]
Thorney
Re: Shortshifters
Post by Thorney » Fri Jan 31, 2003 10:35 am
LOL.
So, Bushy, are you sure you've got an RS4 and not an Octavia Estate [img]images/graemlins/wink.gif[/img] [img]images/graemlins/grin.gif[/img]
johneroberts
Re: Shortshifters
Post by johneroberts » Fri Jan 31, 2003 10:46 am
Sharp in take of breath.....I take it your were told it was a Tanoga....by Scott or one of the guys at AmD...seems like you need to make a call [img]images/graemlins/nodder.gif[/img]
jr
RS246 Founder
Bushy
Re: Shortshifters
Post by Bushy » Fri Jan 31, 2003 10:59 am
LOL
LO even L [img]images/graemlins/roflmao.gif[/img]
That is so funny
No wonder yours is [censored]
Better bring it on Monday and one of yours Carl
How much do i owe you as i will bring the dosh too
Bushy
Re: Shortshifters
Post by Bushy » Fri Jan 31, 2003 11:04 am
Karl, sorry spelt your name wrong before [img]images/graemlins/blush.gif[/img]
Just looked at your site and notice the links from the shift page point to RS$.org
better get that changed mate
Bushy
Re: Shortshifters
Post by Bushy » Thu Feb 06, 2003 7:56 am
Well to finish this thread off I must explain that eh shift i had was probably a Stratmosphere one
As i believe the UUC one is well engineered
The bottom linkage has a steel secion (the gear lever) with a bearing in it, good idea to save wear, this has an aluminium forked piece which connects to the gear linkage and is bolted through the bearing
However theis is pooor as the bolt has worn the aluminium piece and in fact has not needed the bearing as it has rubbed on the aluminium section
Clear as mud?
Basically i have gained around 5mm of play in the shift which cannot help when selecting gears, this has happened over say 15k miles and cannot be good for the car!
I am now the proud owner of a tanoga shift, no contest, much better engineered and feels superb, the throw has been reduced, as the last one had 2 settings 20% and 40%, the Tanoga is 50% and feels really positive
I am sure the car drove quicker on the way home yesterday [img]images/graemlins/thumb.gif[/img] [img]images/graemlins/jump_clap.gif[/img]
Thanks Karl, should have just gone straight to you the first time round.
So the Tanoga fits S4/RS4 hurry up and get one for the S3 guys. They will appreciate it as much as I do, [img]images/graemlins/wink.gif[/img]
DavidT
Re: Shortshifters
Post by DavidT » Thu Feb 06, 2003 9:51 am
Karl put one on my S4 yesterday. Amazing, best money I have ever spent on a car.
Highly recommended, must be the best cost/benefit mod available for RS4/S4.
David
PhilT
RS246.com
Re: Shortshifters
Post by PhilT » Thu Feb 06, 2003 10:18 am
Here, here. [img]images/graemlins/thumb.gif[/img]
Thorney
Re: Shortshifters
Post by Thorney » Thu Feb 06, 2003 10:31 am
How much and how long to fit?
