Bushy
I have a theory as to what has caused the problem you discribe, but I need to look at it to be certain.
Whatever the outcome, be it defect or incorrect instalation, I will replace it foc and if we can make the arrangements I will fit it into your car.
I don't know if I can do it on the 3rd, if not then I am sure I could do it at the rolling road meet on the 5th.
Karl
Superb Carl
I knew that you would, never doubted you mate. Service makes all the differnce these days, get your Tanoga shifts here - advertising/marketting mode off [img]images/graemlins/grin.gif[/img]
I see the bearing you useis in fact strong enough for the job, which was my initial thought on the subject, it is where the bolt goes through the aluminium shaft that it has worn, i suggest some sort of insert to stop wear.
But when you get it you can comment
Also i did not really realise your shift had 2 settings so when i get it fitted next time i will go for the 40 degree no the 30 degree
At the rolling road will be great mate
