Info for those looking at RNSE upgrades
sync24
Re: Info for those looking at RNSE upgrades
Post by sync24 » Tue Feb 12, 2013 4:39 pm
Gizmo68 wrote: I will take that as a no then?
Sorry mate - a bit slow on the response... Anyway - no it still does not have a 7 digit postcode search but I found the combo of 4 digit and almost instant road lookup and select just as usable. Prob here I see as if you don't know what the road is called at the 4 digit Post code location you are stuffed!
sync24
Post by sync24 » Tue Feb 12, 2013 4:41 pm
MikeFish wrote:Is it possible to retrofit the multifunction wheel? I didn't think you could.
Apparently you can - a TT-RS wheel will fit with a relocation of the SPORT button and a fair few £££££ spent on the TT-RS MF FBSW with airbag/wiring loom
PetrolDave
Post by PetrolDave » Tue Feb 12, 2013 6:56 pm
sync24 wrote:You mean use the digital TV signal for DAB
The radio stations on Freeview are not the same ones as on DAB, many are common but not all.
Post by MikeFish » Tue Feb 12, 2013 9:00 pm
You say that but on many occassions I have entered the postcode (well as much as it will let me) then the name of the road, then it comes up with 2 or more options still, most of the time I have no idea which of the options it is as the yare very similar and you can bet that I always pick the wrong one and end up in the wrong place.
Rick_RS4
Post by Rick_RS4 » Tue Feb 12, 2013 11:37 pm
so can we not wire in a button on the dash to work voice activation?
sync24
Post by sync24 » Wed Feb 13, 2013 8:21 am
Rick_RS4 wrote:so can we not wire in a button on the dash to work voice activation?
I would have thought that is not possible as AFAIK the vagcom is programmed for either a FBSW or a MFSW - however someone else who knows VAGCOM inside out should comment - maybe start a thread in 'electrics' ?
PetrolDave
Post by PetrolDave » Wed Feb 13, 2013 7:24 pm
Nope, the RNS-E looks for a CAN bus message that the "Talk" button has been pressed on the MFSW.
So you need to wire a button to a "box of tricks" that genberates the CAN bus message. A member on audiforum.us called bjarne USED to make a box that did that (as a side effect of fixing some problems with the clock when retrofitting an RNS-E into a B5), but he doesn't make them any more.
Rick_RS4
Post by Rick_RS4 » Wed Feb 13, 2013 11:18 pm
ah ok, nevermind
thanks for the info
esp_mm-270
Post by esp_mm-270 » Tue Jun 04, 2013 11:17 am
Thats a shame, I'd prefer to add a talk button than change steering wheel and move the 'S' button.
esp_mm-270
Post by esp_mm-270 » Tue Jun 04, 2013 11:33 am
I've been reading that phone cradles (or some of them) have talk buttons? Can we not butcher one of those to do a job for this?
adsgreen
Post by adsgreen » Tue Jun 04, 2013 12:28 pm
esp_mm-270 wrote:I've been reading that phone cradles (or some of them) have talk buttons? Can we not butcher one of those to do a job for this?
yes the cradles do have the push to talk button.
Return to “Electrical”
Users browsing this forum: No registered users and 95 guests
