Sorry mate - a bit slow on the response... Anyway - no it still does not have a 7 digit postcode search but I found the combo of 4 digit and almost instant road lookup and select just as usable. Prob here I see as if you don't know what the road is called at the 4 digit Post code location you are stuffed!Gizmo68 wrote: I will take that as a no then?
Info for those looking at RNSE upgrades
Re: Info for those looking at RNSE upgrades
Apparently you can - a TT-RS wheel will fit with a relocation of the SPORT button and a fair few £££££ spent on the TT-RS MF FBSW with airbag/wiring loomMikeFish wrote:Is it possible to retrofit the multifunction wheel? I didn't think you could.
- PetrolDave
The radio stations on Freeview are not the same ones as on DAB, many are common but not all.sync24 wrote:You mean use the digital TV signal for DAB
You say that but on many occassions I have entered the postcode (well as much as it will let me) then the name of the road, then it comes up with 2 or more options still, most of the time I have no idea which of the options it is as the yare very similar and you can bet that I always pick the wrong one and end up in the wrong place.sync24 wrote:
so can we not wire in a button on the dash to work voice activation?
I would have thought that is not possible as AFAIK the vagcom is programmed for either a FBSW or a MFSW - however someone else who knows VAGCOM inside out should comment - maybe start a thread in 'electrics' ?Rick_RS4 wrote:so can we not wire in a button on the dash to work voice activation?
- PetrolDave
Nope, the RNS-E looks for a CAN bus message that the "Talk" button has been pressed on the MFSW.Rick_RS4 wrote:so can we not wire in a button on the dash to work voice activation?
So you need to wire a button to a "box of tricks" that genberates the CAN bus message. A member on audiforum.us called bjarne USED to make a box that did that (as a side effect of fixing some problems with the clock when retrofitting an RNS-E into a B5), but he doesn't make them any more.
ah ok, nevermind
thanks for the info
thanks for the info
- esp_mm-270
Thats a shame, I'd prefer to add a talk button than change steering wheel and move the 'S' button.PetrolDave wrote:Nope, the RNS-E looks for a CAN bus message that the "Talk" button has been pressed on the MFSW.Rick_RS4 wrote:so can we not wire in a button on the dash to work voice activation?
- esp_mm-270
I've been reading that phone cradles (or some of them) have talk buttons? Can we not butcher one of those to do a job for this?
yes the cradles do have the push to talk button.esp_mm-270 wrote:I've been reading that phone cradles (or some of them) have talk buttons? Can we not butcher one of those to do a job for this?
Users browsing this forum: No registered users and 159 guests
