Any help much appreciated
Help with sourcing vac lines etc.
- Weiß-sechs
- 5th Gear
- Location: Everywhere & nowhere baby, that's where I'm at...
So, the inevitable has happened (after racking over 190K miles). Perished plumbing under the the inlet manifold. Obviously, all parts required are NLA from TPS...just wondering if any of you guys have replaced these lines recently & manged to find them? Hoping to do the lot while we're in there including the after run pump if poss. Part numbers gratefully received too.
Re: Help with sourcing vac lines etc.
@TOPMAN may be able to assist
Thanks NickTechNick wrote:@TOPMAN may be able to assist
Hi White Six!Weiß-sechs wrote:So, the inevitable has happened (after racking over 190K miles). Perished plumbing under the the inlet manifold. Obviously, all parts required are NLA from TPS...just wondering if any of you guys have replaced these lines recently & manged to find them? Hoping to do the lot while we're in there including the after run pump if poss. Part numbers gratefully received too.
Looks like you have a POPPED SJP (suction jet pump). An increasingly common failure these days.
Looks like you’ve done the hard work already, how can I help? What do you need?
Regards
Craig Barlow
allroadadi
Wait, you were able to remove the intake manifold without removing the front end?
Yes you can, I did this job a couple of months ago.allroadadi wrote: ↑Sun May 04, 2025 5:12 pmWait, you were able to remove the intake manifold without removing the front end?![]()
@ Weiß-sechs do yourself a favour and change that water pump while you have it apart. The SJP is still available from TPS as used on other VAG cars. Craig (Topman) should have a link for a silicon hose kit I can't find it sorry.
allroadadi wrote:Wait, you were able to remove the intake manifold without removing the front end?
You most certainly can
Just unbolt and it will pull forward enough to get the job done
Regards
Craig
TOPMAN wrote:allroadadi wrote:Wait, you were able to remove the intake manifold without removing the front end?
You most certainly canJust unbolt and it will pull forward enough to get the job done
Regards
Craig
- Weiß-sechs
- 5th Gear
Ooh, that looks sexy CraigTOPMAN wrote: ↑Sun May 04, 2025 10:15 amHi White Six!Weiß-sechs wrote:So, the inevitable has happened (after racking over 190K miles). Perished plumbing under the the inlet manifold. Obviously, all parts required are NLA from TPS...just wondering if any of you guys have replaced these lines recently & manged to find them? Hoping to do the lot while we're in there including the after run pump if poss. Part numbers gratefully received too.
Regards
Craig Barlow
Looks like you've collected all the pipework needed...silicon hoses? Is there a kit available of all the plumbing needed or did you make a "shopping list" and sourced individually? If you've got linkies or part numbers for all the gubbins, that'd be fantastic my man!
SJP still available then? And, looking at replacing the after run pump while in there (thanks Bilko1)
- Weiß-sechs
- 5th Gear
Thank you bud
Shame they're Stateside & not Europe but when needs must...
They are in SwedenWeiß-sechs wrote: ↑Mon May 05, 2025 6:42 pmThank you bud![]()
- Weiß-sechs
- 5th Gear
Users browsing this forum: Quinten and 67 guests
