New owner needing somexadvice
RS6C5avant
Post by RS6C5avant » Mon Apr 07, 2025 2:49 pm
Hello ,ive just bought c5 rs6 Avant (54) from a mate who recently ( couple iof weeks) purchased it.The second day he had it the brakes failed no servo assist, has been smoke tested and appears to be leaking from left side front on engine ,under the inlet manifold.
I've read this is quite common fault and is the suction pump/ valve situated under the inlet ,would anyone have part number of it and any tips hints for other parts i need or should replace while doing this. Thanks for reading
pwack
Re: New owner needing somexadvice
Post by pwack » Mon Apr 07, 2025 3:34 pm
See post below
viewtopic.php?t=133768
RS6C5avant
Post by RS6C5avant » Wed Apr 09, 2025 11:46 am
Thank you ,that perfect
RS6C5avant
Post by RS6C5avant » Wed Apr 09, 2025 12:29 pm
The dealer no longer has the gaskets ,but managed to get 2 online ,the pump they can get though will be a few days £60 ,i see topran ones online for less than a £10 , is it worth the risk anyone used a non genuine one ?
pwack
Post by pwack » Wed Apr 09, 2025 3:34 pm
https://www.ebay.co.uk/itm/387854661328?
link to audi unit from A6 , think its the same but check part number against RS6 unit
RS6C5avant
Post by RS6C5avant » Fri Apr 11, 2025 10:33 am
Got an OEM one from LLL parts ty
I was looking at diagrams for fitting this and wonder if anyone rerouted this ,the feed comes from join at the bulk head and under manifold then comes up to the n249 with other side going to vac reservior, I'm think of replacing hose from bulk head and running it above the intake to the valve and then running new pipe to reservior , anyone tried it ? Or know why it wouldn't work.
Felix2566
Post by Felix2566 » Fri Apr 11, 2025 11:42 am
I think you'll run into clearance problems between the top of the manifold and the inlet plenum, it sits pretty tightly together. Probably why they routed it as they did.
Unless you route it completely away from the manifold, but might look quite messy?
TOPMAN
Post by TOPMAN » Fri Apr 11, 2025 12:03 pm
Hello!
Did mine last year, you should replace a bunch of stuff while the manifold is off.
The after run pump, the IAT sensor, any suspect pipes, fuel regulator, injector seals, the SJP, MAF connector plugs if needed, MAF seals, boost pipe return seals etc etc
By the way, the SJP can be re-routed to the bulk-head if you want, but it has lasted under there for more than 20 years, so I didn't bother. I think half of these SJP's fail because it's simply so hot and hostile in that area. It doesn't help that many of these after-run pumps simply don't work, thus providing no cooling for the turbos. The SJP has 3 feeds (2 in and 1 out) you would need to run 2 pipes from under the manifold up to the SJP mounted on the bulk-head. Of course the tap on the inlet manifold is facing in the totally wrong direction, so you would need to heat that up and turn it towards the rear. Another idea is to get rid of the SJP all together, block of the F connector and replace the SJP with a one-way check valve. This is what I will do if it goes again during my ownership :-)
I can send you more info if you need - I don't monitor this forum much, so probably easier to contact me in one of the FB groups.
My intake manifold photo attached
Regards
Craig Barlow
bilko1
Post by bilko1 » Fri Apr 11, 2025 12:05 pm
Topman and myself have recently gone through this. I got all parts from Autodoc except the injector seals which came from mr injector. https://www.mrinjectoruk.co.uk/products ... pFtiO6lwlM
Edit
I lied, the SJP came from TPS as still available as fitted to other VAG cars.
steve2003rs6
Post by steve2003rs6 » Sat Apr 12, 2025 1:37 pm
Had to replace mine some time ago. Almost crapped myself when I braked hard and there was nothing.
RS6C5avant
Post by RS6C5avant » Tue Apr 15, 2025 1:56 pm
Thanks everyone, I will look into the other parts( was hoping for a smaller list though lol) any tips on replacing pipe clips, ,I do fancy rerouting but probably safer removing the inlet anyway just to be sure were its actually leaking,I know these valves are fitted to 1.8T and other VW Audis and never seen one fail,so I'm quite sure it simply the positioning ,must get hot under there.
Was looking through the cars history and there a invoice for the car being scanned for Grand Turismo
RS6C5avant
Post by RS6C5avant » Tue Apr 15, 2025 5:16 pm
After looking at your manifold picture there no way it being rerouted without taking the manifold off,I got a mate at Audi to print of there removal diagrams, and it makes it look like the SJP it's not actually connected to anything under the manifold ( shows n249 and the reservior as being the connection ,then feeding bulkhead .
Well I will order the other stuff tonight thanks everyone
The injector dude is on holiday
RS6C5avant
Post by RS6C5avant » Tue May 06, 2025 5:17 pm
Would anyone have the part numbers
For the
Turbo after run pump
IAT sensor
Fpr
Maf seals
Tried search autodoc but can't find any off them
steve2003rs6
Post by steve2003rs6 » Tue May 06, 2025 5:32 pm
lll.parts.co.uk/catalogs is a great source of information.
bilko1
Post by bilko1 » Tue May 06, 2025 8:17 pm
Pump is PIERBURG 7.02074.75.0
IAT is BOSCH 0 280 130 060
Thats from Autodoc
There was a post about alternative MAF seals in the forum a while ago I bought some and they are fine
Craig aka TOPMAN will probably know the Autodoc part numbers for the other items.
Just found this
FEBI BILSTEIN 173904 Fuel pressure regulator 4 bar
Users browsing this forum: ALE-RS6 and 91 guests
