Breakdown
steve2003rs6
Re: Breakdown
Post by steve2003rs6 » Fri Nov 08, 2024 7:50 pm
No Ben. Still the old fuel tank pump.
It’s probably finally packed up.
Re: Breakdown
Post by Shoppinit » Fri Nov 08, 2024 7:55 pm
Sounds like it. Try not to get too depressed. Have some more weird pizza and wash it down with a decent whisky.
steve2003rs6
Re: Breakdown
Post by steve2003rs6 » Fri Nov 08, 2024 8:15 pm
That was a special mixed kebab Ben.
It went down really nicely.
As did the scotch.
Watched a video on how to change the in tank fuel pump. Think I will pass on that one.
Need to get some help.
Re: Breakdown
Post by Shoppinit » Fri Nov 08, 2024 8:33 pm
I replaced the in-tank pump in my Volvo. It was an utter ball ache of a job. All the interior had to come out from behind the front seats.
I think the RS6 will be easier.
steve2003rs6
Re: Breakdown
Post by steve2003rs6 » Sat Nov 09, 2024 10:27 am
Yes mate. Access is under the rear seat.
Only other thing I can think of is a duff fuel pressure regulator ?
Still unable to start the car. Hopefully get some help today.
No one turned up yesterday.
srichards
Re: Breakdown
Post by srichards » Sat Nov 09, 2024 10:31 am
Or fuel pump relay perhaps?
Re: Breakdown
Post by Shoppinit » Sat Nov 09, 2024 10:31 am
Yeah, could be a duff fuel regulator. But it sounds more like your external pump is cavitating which would imply an upstream problem rather than a downstream problem.
Re: Breakdown
Post by Shoppinit » Sat Nov 09, 2024 10:40 am
Maybe. I don't think so given the preceding symptoms. It's quite easy to check though.
TOPMAN
Re: Breakdown
Post by TOPMAN » Sat Nov 09, 2024 10:48 am
Shoppinit wrote:Yeah, could be a duff fuel regulator. But it sounds more like your external pump is cavitating which would imply an upstream problem rather than a downstream problem.
Yep - this is the culprit in my opinion…
steve2003rs6
Re: Breakdown
Post by steve2003rs6 » Sat Nov 09, 2024 12:02 pm
Now to see if I can get it out and the replacement in.
steve2003rs6
Re: Breakdown
Post by steve2003rs6 » Sat Nov 09, 2024 12:12 pm
Came across this.
Anyone know its location.
IMO it’s too cheap. Will look for a OEM One.
Re: Breakdown
Post by Shoppinit » Sat Nov 09, 2024 12:31 pm
Engine bay just before the fuel rail for the injectors.
TOPMAN
Re: Breakdown
Post by TOPMAN » Sat Nov 09, 2024 12:43 pm
steve2003rs6 wrote:
Came across this.
In my experience they rarely go bad. The plastic filter can break but it still functions if broken. I recently change the O rings as a precaution, which is a kit for a couple of quid. Mine is from 2004 and the O rings were in good shape.
Just make sure you buy the 4.0 bar version as other versions exist. The pressure is stamped into the body.
Here in my picture, you can see both the Bosch and Audi part numbers :-)Image
TOPMAN
Re: Breakdown
Post by TOPMAN » Sat Nov 09, 2024 12:50 pm
As Ben has mentioned, it’s on the fuel rail (circled).
Pretty easy job to change once the airbox has been removed. Remember to release the fuel pressure otherwise you will get an eye full ;-)
steve2003rs6
Re: Breakdown
Post by steve2003rs6 » Sat Nov 09, 2024 12:57 pm
Cheers Ben/craig.
The one I am about to order is 4 bar rated.
If it is faulty then I have it available.
If it’s not faulty then it will be replaced during next full service.
Users browsing this forum: Bing [Bot] and 94 guests
