Breakdown
Re: Breakdown
Post by Shoppinit » Thu Nov 07, 2024 7:17 pm
It’s weird that you’ve got the same problem on both pumps. I don’t believe much in coincidences.
The pump noise might be cavitation.
How old is your fuel filter?
I wonder if there’s a tank ventilation issue. I had a problem like that with my M3 E36. Long time ago. Try driving the car with the fuel filler cap off to test.
Steve2003rs6
Re: Breakdown
Post by Steve2003rs6 » Thu Nov 07, 2024 7:25 pm
Brand new filter installed at the same time as the replacement pump.
Will remove the fuel cap Ben.
Re: Breakdown
Post by Shoppinit » Thu Nov 07, 2024 7:29 pm
It might throw a code without the fuel cap on. It’s just to see what happens. If there’s a difference.
Steve2003rs6
Re: Breakdown
Post by Steve2003rs6 » Thu Nov 07, 2024 7:31 pm
Okay mate will remove the fuel cap in the morning.
srichards
Re: Breakdown
Post by srichards » Fri Nov 08, 2024 9:00 am
Some of the code readers have an EVAP Check thingy. Worth trying that?
Steve2003rs6
Re: Breakdown
Post by Steve2003rs6 » Fri Nov 08, 2024 10:12 am
This is the error message.
On start up uneven revs and an intermittent noise that you can hear while sat in the cabin.
I am wondering if it’s the pump inside the fuel tank.
At the moment it’s settled down and even revs and no noise.
Re: Breakdown
Post by Shoppinit » Fri Nov 08, 2024 10:32 am
Yeah, if the lifter pump isn’t feeding properly that could cause the main pump to be starved. Good job you’ve got a spare in-tank pump now. :)
I’m not familiar with that error code. I’m going to look it up.
Re: Breakdown
Post by Shoppinit » Fri Nov 08, 2024 10:33 am
Or maybe there is an air leak between the pumps and the main pump is drawing in air. Doesn’t seem particularly likely.
Steve2003rs6
Re: Breakdown
Post by Steve2003rs6 » Fri Nov 08, 2024 10:50 am
Just driven 100 yards. Started off ok then Jumpy and uneven.
Pressing down on accelerator no increase in speed.
Just managed to get back home.
Re: Breakdown
Post by Shoppinit » Fri Nov 08, 2024 10:54 am
That's without the fuel tank cap?
The more I think about it, the more I think it might be the lifter pump in the tank.
Did you keep the original external fuel pump?
Steve2003rs6
Re: Breakdown
Post by Steve2003rs6 » Fri Nov 08, 2024 11:04 am
Hey Ben.
Yes mate fuel cap off.
I kept the old external fuel pump.
Phoned a mate. He might be available to change the pump on my drive. Will let me know soonish.
Garage earliest 20 th this month.
Steve2003rs6
Re: Breakdown
Post by Steve2003rs6 » Fri Nov 08, 2024 2:14 pm
Car won’t start at all now.
srichards
Re: Breakdown
Post by srichards » Fri Nov 08, 2024 2:32 pm
I'd probably disconnect the battery for 10 minutes and try again in an hour. Give it time to think about what it's done.
Steve2003rs6
Re: Breakdown
Post by Steve2003rs6 » Fri Nov 08, 2024 6:05 pm
Thank you Suz.
Will give it a go tomorrow.
Re: Breakdown
Post by Shoppinit » Fri Nov 08, 2024 7:18 pm
Is this with the new pump in the tank?
Users browsing this forum: Google [Bot] and 121 guests
