Easiest way to turn engine over without start?
TOPMAN
Post by TOPMAN » Sun Sep 22, 2024 12:08 pm
Hi all
This is going to be any easy question to answer for some, but today I'm struggling to find the answer.
Engine has been sat a while as I have been taking my time with the SJP install. With fluids dropped and various bits changed, I'd like to start the car systematically. I assume it might be easiest to pull the connector for G28, but I can't find where it connects to the loom. Can someone point me in the right direction please :bigblink:
Thanks in advance...
Re: Easiest way to turn engine over without start?
Post by Shoppinit » Sun Sep 22, 2024 12:10 pm
Look in the FAQ. There's a procedure.
Post by Shoppinit » Sun Sep 22, 2024 12:11 pm
Saved you the trouble:
shoppinit wrote: Oil system pressurising after long time standing
Pull fuse 29 and turn the engine over for about 5 seconds to prime the pump. Put fuse back in and start normally.
It's the last to bottom fuse on the left IIRC.
Jayjay101
Post by Jayjay101 » Sun Sep 22, 2024 12:12 pm
TOPMAN wrote:Hi all
I always pull fuse 29 and 28 and let the oil pressure build up then start the engine
Post by Shoppinit » Sun Sep 22, 2024 12:12 pm
You don't need to pull 28. 29 is enough. Also it won't leave any fault codes.
Jayjay101
Post by Jayjay101 » Sun Sep 22, 2024 12:19 pm
Shoppinit wrote:You don't need to pull 28. 29 is enough. Also it won't leave any fault codes.
Thanks mate! It’s only because it stinks of fuel I pull 28
Post by Shoppinit » Sun Sep 22, 2024 2:45 pm
Yeah. I suppose if you’re going to turn it over for a lot time that makes sense to pull 28 too.
TOPMAN
Post by TOPMAN » Wed Sep 25, 2024 5:03 pm
Thanks guys!
Apologies for the late reply, but I took this advice into action immediately. It was very useful, thanks.
Regards
Craig
Users browsing this forum: MeTsU, Shoppinit and 66 guests
