Need a replacement ABS module
ALE-RS6
Post by ALE-RS6 » Sat Aug 10, 2024 5:04 pm
My ABS module was sent away for refurbishment due to ongoing issues, and they have come back and said it's beyond repair. They said it has previously been repaired once before. So I'm on the hunt for a 2nd hand or refurbished unit part ref '4B0614517AD'. If anyone by chance has one or know of someone that might, let me know or send me a DM.
The car is in with an Audi specialist at the moment and they sent the module away to a company they use frequently and it's the first time they've not been able to repair one (typical! - didn't catch the name of the ABS repair company).
srichards
Re: Need a replacement ABS module
Post by srichards » Sat Aug 10, 2024 5:16 pm
srichards
Post by srichards » Sat Aug 10, 2024 5:19 pm
There's 3 that look visually similar on the passat page as well:
https://www.ecutesting.com/product-cata ... -combined/
ALE-RS6
Post by ALE-RS6 » Sat Aug 10, 2024 5:32 pm
Thanks bud, I think they offer a refurbishment service rather than the actual replacement part?
srichards
Post by srichards » Sat Aug 10, 2024 5:43 pm
You could contact Ecu Testing and ask them if they can repair one that has already been repaired. They also may be able to tell you whether the ones that look the same are the same and are interchangeable. If they are that gives you a bigger pool of used ones to access.
ALE-RS6
Post by ALE-RS6 » Sat Aug 10, 2024 6:01 pm
Yeah I'll try contact them and see what they say. Have you had any dealings with them in the past?
srichards
Post by srichards » Sat Aug 10, 2024 6:08 pm
No but I think others have used them before and found them ok.
111marc111
Post by 111marc111 » Sun Aug 11, 2024 8:21 am
I used "ecu testing" for three abs pump on my Rs6 and they were fab. Also used them for a bmw and they solved that one too.
Their website is also very good. Have a look because I'm sure they not only refurbish your sent in unit but they also sell refurbished replacements.
Have a look on their website. They are defo worth a call
ALE-RS6
Post by ALE-RS6 » Sun Aug 11, 2024 10:39 am
That's good to know, thanks. I've contacted ECU testing and I'm going to speak with the garage in the morning to get some more details on the faulty unit.
Felix2566
Post by Felix2566 » Sun Aug 11, 2024 1:47 pm
Another positive for ECU testing, they repaired my ABS module too
ALE-RS6
Post by ALE-RS6 » Mon Aug 12, 2024 7:37 pm
I spoke with the garage this morning and they did in fact send it to ECU testing. They didn't have a suitable replacement either unfortunately. There's some reassurance knowing ECU testing looked at it. So after much digging, I managed to find a second hand unit from a breaker sold in working condition. The part should arrive mid week for fitting so fingers crossed.
ALE-RS6
Post by ALE-RS6 » Mon Aug 12, 2024 7:47 pm
Forgot to mention, I also received a quote for a special order new unit from Germany for the princely sum of £3,300.00 :shock:
hahnmgh63
Post by hahnmgh63 » Tue Aug 13, 2024 12:29 am
Until guys figured out the coding for the ABS to work with the 6spd manual there were some guys that used a Passat unit so there must be one around the same year that is pretty close, if they got it work with the 6spd they can probably get it to work with the crappy ZF 5HP.
Users browsing this forum: srichards and 242 guests
