Door open warning fault
Had a week fault free
but now my car thinks all 4 doors are open when there not resulting in it beeping all the time. I ran the battery flat earlier if that points to the issue I am having an does anyone know how to fix it.
Re: Door open warning fault
Sounds like your CCM is having a bad day. I’d disconnect the battery and reconnect after 1/2 hour. Make sure it has a good charge in it
The car alarm also keeps going off
Cheers will give it a go. Is there a fuse I can pull to stop it beeping as I am off an 600 mile round trip Friday.
Faults still there
What does the Vagcom say?
I ve only got the onboard one I can take it to my mate tomorrow though.
I ve took the CCM out an checked the floor which is dry.
Just found it odd that after I let the battery go flat this fault has happened.
Yeah. It’s odd that it’s soiled its pants like this.
The battery might be coincidence. Or maybe the battery is a symptom, not a cause. Vagcom will tell you what the CCM thinks is happening with door sensors etc.
Does the CCM control the windows amd central aswell as the remote central locking had been playing up for abit an new batteries didn't do anything.
I ve left the brown plug out an that's stopped the door open from going off.
Is the harness under the seats linked to the CCM at all as I was messing around with it prior to the battery dying an the door fault was not there before the battery died and I messed about with the harness.
Update on this. Replaced the CCM and the only fault I have now is the central locking as it doesn't work either by putting key in door or off the fob.
As its a different CCM will it need programming?
Check the coding with the Vagcom
Touch wood everything working as it should. No idea why or how it started working but I am not complaining.
Users browsing this forum: Google [Bot], srichards and 94 guests
