Door open warning fault
Frazz82
Post by Frazz82 » Wed Feb 28, 2024 6:03 pm
Had a week fault free :D but now my car thinks all 4 doors are open when there not resulting in it beeping all the time. I ran the battery flat earlier if that points to the issue I am having an does anyone know how to fix it.
TOPMAN
Re: Door open warning fault
Post by TOPMAN » Wed Feb 28, 2024 6:05 pm
Sounds like your CCM is having a bad day. I’d disconnect the battery and reconnect after 1/2 hour. Make sure it has a good charge in it
Frazz82
Post by Frazz82 » Wed Feb 28, 2024 6:15 pm
The car alarm also keeps going off
Frazz82
Post by Frazz82 » Wed Feb 28, 2024 6:30 pm
Sounds like your CCM is having a bad day. I’d disconnect the battery and reconnect after 1/2 hour. Make sure it has a good charge in it Image
Cheers will give it a go. Is there a fuse I can pull to stop it beeping as I am off an 600 mile round trip Friday.
Frazz82
Post by Frazz82 » Wed Feb 28, 2024 8:10 pm
Faults still there
Post by Shoppinit » Wed Feb 28, 2024 8:32 pm
What does the Vagcom say?
Frazz82
Post by Frazz82 » Wed Feb 28, 2024 9:37 pm
I ve only got the onboard one I can take it to my mate tomorrow though.
I ve took the CCM out an checked the floor which is dry.
Just found it odd that after I let the battery go flat this fault has happened.
Post by Shoppinit » Wed Feb 28, 2024 10:39 pm
Yeah. It’s odd that it’s soiled its pants like this.
The battery might be coincidence. Or maybe the battery is a symptom, not a cause. Vagcom will tell you what the CCM thinks is happening with door sensors etc.
Frazz82
Post by Frazz82 » Thu Feb 29, 2024 5:57 pm
Does the CCM control the windows amd central aswell as the remote central locking had been playing up for abit an new batteries didn't do anything.
I ve left the brown plug out an that's stopped the door open from going off.
Frazz82
Post by Frazz82 » Thu Feb 29, 2024 7:25 pm
Is the harness under the seats linked to the CCM at all as I was messing around with it prior to the battery dying an the door fault was not there before the battery died and I messed about with the harness.
Frazz82
Post by Frazz82 » Wed Mar 13, 2024 7:47 pm
Update on this. Replaced the CCM and the only fault I have now is the central locking as it doesn't work either by putting key in door or off the fob.
As its a different CCM will it need programming?
Post by Shoppinit » Wed Mar 13, 2024 8:13 pm
Check the coding with the Vagcom
Frazz82
Post by Frazz82 » Sat Mar 16, 2024 4:28 pm
Touch wood everything working as it should. No idea why or how it started working but I am not complaining.
