01304 error.
01304 error.
Sort 1 fault then get another one (or two).
Address 17 instruments.
01304 radio error
49:00 communication
Radio works as normal.
Anyone familiar with this error.
01304 radio error
49:00 communication
Re: 01304 error.
You’ve got an aftermarket radio, haven’t you?
Re: 01304 error.
No Ben. Original rnsd radio.
Very recent error.
Very recent error.
Re: 01304 error.
Could be the TMC module. That handles the translation between the RNSD and the CAN comms of the rest of the car. Presumably you’ve got no radio info on the DIS either?
Re: 01304 error.
Thank you Ben. Will look into it.
Re: 01304 error.
You could always try disconnecting the TMC for a while to see if that helps.
I think one of the first issues I ever had with my car was the TMC module. Can’t remember what it was exactly, but replacing it fixed it.
It used to be easy to source TMC modules because people would get rid of them when upgrading to RNS-e (which doesn’t use them).
Re: 01304 error.
Get this when I turn the radio on.
Re: 01304 error.
I've recently found, near the passenger seat right slider, the join of power cables coming from the radio and the amp/possibly nav too.
They're joined with one of those aluminium crimps and the cables basically fell apart when touched.
I had progressively worsening radio problems.
Re: 01304 error.
PhilS2. Thank you for your input.
Ben does the above photo confirm your TMC module recommendation.
Re: 01304 error.
Yeah, that’s the fault I had. I remember now. But worth checking what PhilS2 mentioned. Could be wiring, especially if someone’s been messing in the area.
Re: 01304 error.
Just done a lot of reading on this from MalcolmSu-shoppinit messages on the same subject from 2015.
Basically Fcuk that. Will leave it for now as the radio functions ok.
Re: 01304 error.
If you can find a cheap TMC module then nab it and chuck it in. It might resolve your problem.
Re: 01304 error.
Will keep a look out for one. Thanks mate.
Re: 01304 error.
Car was in garage on Friday for work.
These errors were not present previously.
Reckon they must of accidentally disturbed something when changing the park assist module and buzzer.
Re: 01304 error.
That could all be due to the TMC module.
Users browsing this forum: No registered users and 100 guests
