Normal oil and coolant temperatures
Re: Normal oil and coolant temperatures
Post by Shoppinit » Sun Aug 13, 2023 11:23 am
No
Post by Shoppinit » Sun Aug 13, 2023 12:19 pm
Oil temp is available in group 134, ECU.
Also in instrument cluster, group 50.
Swan
Post by Swan » Sun Aug 13, 2023 3:26 pm
Amazing thank you so much. VCDS on order. Will investigate and report back
Swan
Post by Swan » Fri Aug 18, 2023 9:28 pm
So - interesting development. I have gone for a spirited drive this evening and given it the full beans. Gauge indicating 90C coolant and 120C engine oil.
Half way through the drive the engine oil gauge dropped swiftly to 90c.
I then drove around town at a leisurely pace to see if it would increase again. It did not. Stayed at 90C on both gauges.
When I turned the engine off the afterruns fans didn’t even start up and subjectively the heat coming from the engine bay did seem less hot.
Do you think I have a sticky thermostat? And the spirited drive increased the oil pressure enough to unstick it?
Swan
Post by Swan » Sat Aug 19, 2023 9:25 am
Went for another enthusiastic drive this morning and oil temp is stuck on 120…… any theories?
Classik
Post by Classik » Wed Aug 23, 2023 6:10 pm
FWIW standard coolant temp on the dashboard always stays at 90 here and on VCDS I get a stable 98°C when engine hot.
For the oil temp, on the dashboard it depends on the driving, but never goes above 110 here. For peace of mind I would replace the oil temp sensor (can't remember if it's easy to access though). If it stays high, you may have a clogged oil cooler (the one at the front which also serves to cool transmission oil).
RS6 C5 Avant 2003 Daytona Grey
Loba 650 turbos - Wagner IC - 200 cells cats - Milltek cat-back - Hotchkis bars - Bilstein B16 - MTM Wheels - oem coolant cap
Post by Shoppinit » Wed Aug 23, 2023 8:16 pm
Yeah, I took mine for a spirited test drive the other day after replacing the rear caliper and the oil temps went up to 110 and the ambient temperature was 38 degrees. If you’re seeing 120 then I’d be looking for a thermostat issue.
Did you measure the coolant temps when your oil was at 120?
rs4wagon
Post by rs4wagon » Sat Aug 26, 2023 11:41 pm
just went to poland 3 weeks ago 1200miles one way,oil max 105 when did 180mph for few minuites, collant 108,valvo 5w50 changed just the day i left uk,before had valvo 5w40 and temps still same,when diving max 100mhp constant oil 90' collant no more than 100'
Swan
Post by Swan » Sun Aug 27, 2023 7:12 pm
Coolant was about 95C.
I’m getting the thermostat and water pump replaced tomorrow (cam belt service). Fingers crossed. Il report back
Swan
Post by Swan » Thu Oct 19, 2023 10:12 pm
So little update.
Cambelt service with new thermostat, water pump, radiator hasn’t solved my oil temperature. (Glad I did it though, there was a leak on the radiator and water pump) Coolant runs at 90, oil temp still at 120 as before.
Mechanic thinks it’s within normal petrol engine tolerance and the oil temp sensor would throw a warning light if it was too hot. I’m still not convinced though, with most people reporting lower temps.
Would engine oil make any difference? Having bought the car 3 months ago, I have no idea what they put in there in the last service. Could this affect oil temps? For example they may have used 5w30 instead of Audi spec 5w40. Or am I barking up the wrong tree? Should I stop being paranoid? lol
Post by Shoppinit » Fri Oct 20, 2023 6:54 am
What’s your ATF temperature when your oil is at 120?
I don’t believe there is a DTC or MIL for excessive oil temp.
Mɐʇʇ
Post by Mɐʇʇ » Fri Oct 20, 2023 2:14 pm
120C for oil isn't the end of the world - my little MG TF frequently sees that.
But it's a bit warm and won't do the oil any favours - plus you'll likely have some hotspots where the oil is well above that. 80-90 is about perfect.
Your RS should, IMVHO, certainly have a normal oil temp of about 90 - and if it doesn't something is up. Can't remember all the oil plumbing off the top of my head though - is the thermostat in the unit bolted to the side of the block where the bufkin pipe goes?
If the car is new to you, I'd see if the cooler pipes are actually connected. The pipes & unions started failing when the cars were about 10 years old - and possibly someone has just bypassed them rather than replaced.
Stick one of these on your oil filter and this'll tell you whether it's a sensor issue, or real issue:
https://uk.rs-online.com/web/p/temperat ... ls/7799772
Post by Shoppinit » Fri Oct 20, 2023 4:05 pm
Shoppinit wrote:
Sat Aug 12, 2023 7:39 am
I have a feeling that there is a mechanical thermostat in the oil cooler circuit. I need to check the workshop manual.
I would replace the oil thermostat. If it's not available separately, then get a whole new cooler. I bought one for my Golf once. Not very expensive:
Mɐʇʇ
Post by Mɐʇʇ » Fri Oct 20, 2023 4:11 pm
Agreed. And looks very accessible - it might fall into that small subsection of the workshop manual that does not start with "Remove Engine".
Steve2003rs6
Post by Steve2003rs6 » Fri Oct 20, 2023 7:18 pm
Had the seals replaced at unit 20 last time I was there.
The large seal had gone really hard over time. Took ages to persuade it out with a hammer and appropriate screwdriver. Eventually came out a small bit at a time. Thankfully lee had a spare seal.
Users browsing this forum: No registered users and 137 guests
