Starting car with no brake calipers
It’s been a long time since I had the RS ticking over. Do you think it’s safe to do so with it in the state that it’s currently in or am I likely to fry the poor girls brain if I do, how much pressure is there to likely to build in the brake hoses when starting?
No brake calipers fitted
Rear drive shafts off
Rear wheel sensors cut off
Re: Starting car with no brake calipers
I’d pull the fuel pump and ignition fuses and turn for about a minute before starting-long as you don’t push the brake pedal I can’t see why it would have a hissy fit
No pressure in the brake hoses unless you press the pedal. It might dribble a bit and if you haven't sealed off the brake hoses you might pull some air in, but you'll be flushing and bleeding anyway so it probably doesn't matter.
Yeah, I can't see the problem in starting it. I would turn it over for a few seconds with fuse 29 pulled to prime the oil ways first.
Fixed it for ya:
I’m never going to live that down!Shoppinit wrote:Fixed it for ya:
Many thanks guys.
Just be careful of those size 13's jabbing the brake pedal.
And don't be surprised when it starts up like a clattery old thing - if been sitting for a few months, very likely some of the lifters will have sunk all the way down. This is not the normal second or 2 of clatter - it's the ticking noise as a lifter sometimes sticks down a bit until everything gets properly warm, which is hard on the driveway.
Cheers Matt.
Users browsing this forum: Bing [Bot], Google [Bot] and 93 guests
