Battery Removal
2.7 V6 30v biturbo - 380 bhp
TWH
Battery Removal
Post by TWH » Fri Feb 10, 2006 9:34 am
I've searched for this and haven't found anywhere which details how to remove the battery. Looking at the engine bay, I'm guessing that it's a case of removing the trim that covers the gap between the engine bay and the windscreen where the battery sits. On cursory inspection it looks like there is too much pipe work either side of the battery to be able to slide it out sideways and it obviously won't come straight out.
Can anyone confirm if the battery can be slid out to the passenger side?
2001 Avus Silver RS4, APRacing 6pots - Gone, but not forgotten :(
PhilT
RS246.com
RE: Battery Removal
Post by PhilT » Fri Feb 10, 2006 9:43 am
Take off the rubber seal that goes between the bonnet gas struts. The whole platic trim should pull away from the windscreen and you will have access to the battery. There's probably a clamp on the base of the battery that you need to undo.
TWH
RE: Battery Removal
Post by TWH » Fri Feb 10, 2006 11:05 am
Cheers for that :thumbs:
Golich
RE: Battery Removal
Post by Golich » Sat Feb 11, 2006 2:55 pm
There are also a couple of plastic 1/4 turn screws that hold this panel tight into the winscreen. As Phil says there is a clamp on the battery 13mm socket required to remove that.
PhilT
RS246.com
RE: Battery Removal
Post by PhilT » Sat Feb 11, 2006 7:49 pm
Not sure you need to touch those.... If you do, be _very_ careful taht you don't wreck them when you turn them.
TWH
RE: Battery Removal
Post by TWH » Sun Feb 12, 2006 10:43 am
Yeah, I noticed that the heads of the screws on that panel were torn to shreds - I could just get enough purchase to turn them and release the panel. Got the battery in now so cheers :)
waitey1
RE: Battery Removal
Post by waitey1 » Sun Feb 12, 2006 4:22 pm
Do you need to put one of those devices in the cigar lighter to ensure continuity of power?
TWH
RE: Battery Removal
Post by TWH » Sun Feb 12, 2006 8:03 pm
I had no problems with anything, just diconnected the old one, then put in the new (about 10 minutes between disconnect and reconnect).
Golich
RE: Battery Removal
Post by Golich » Tue Feb 14, 2006 2:32 pm
That's odd. Because I had to enter my SATNAV+ code.
I was probably longer than 10 mins before I reconnected though.
TWH
RE: Battery Removal
Post by TWH » Fri Feb 17, 2006 4:32 pm
Not sure as I don't have Nav+ so it may be different?
simple1
RE: Battery Removal
Post by simple1 » Fri Feb 17, 2006 4:56 pm
Usually have to put in radio code, I only had my battery off for a couple of minutes to check something and it wiped the radio.... again not sure about sat Nav as I dont have in dash version.
matcook2005
battery hell
Post by matcook2005 » Sun Feb 19, 2006 6:35 pm
yep changed mine - if the passenger sun visor is pulled down the courtesy light stays on - thus 3 weeks away kills battery - and wipes all codes - the trim is attacked by plastic screws which are destroyed when using a screwdriver - joy - and you'll discover the air con filter on your way - which again is dirty - thus servicing is suspect - a complete pain - beware the sun visor
tartan_rob
RE: battery hell
Post by tartan_rob » Mon Feb 20, 2006 10:33 am
be sure and get a big one to put in. I run a 120amp/hr in my S4.
2017 Kawasaki Z1000
2014 RS6
2014 S1
Golich
Re: battery hell
Post by Golich » Mon Feb 20, 2006 9:04 pm
matcook2005 wrote:yep changed mine - if the passenger sun visor is pulled down the courtesy light stays on - thus 3 weeks away kills battery - and wipes all codes - the trim is attacked by plastic screws which are destroyed when using a screwdriver - joy - and you'll discover the air con filter on your way - which again is dirty - thus servicing is suspect - a complete pain - beware the sun visor
Yeah I noticed my pollen filter was filthy too. Which made me suspicious about when it was last changed!
I went for a bigger battery top Bosch one (can't rember the spec) as it had better cold start cranking came with a 4 year warrany and was £30, cheaper i.e. £65 and was a straight fit right down to the little vent hose.
matcook2005
Post by matcook2005 » Mon Feb 20, 2006 10:21 pm
joy i paid 120
