RS6 headlight bulbs
5.0 V10 50v biturbo - 571 bhp
Phuketpaul
Re: RS6 headlight bulbs
Post by Phuketpaul » Sun Jan 15, 2023 9:11 pm
I have the Trups upgrade too.
It's great, works exactly as normal until you switch the fogs on, then you have 2 identical lights,
I.e 2* dipped beams or 2* main beams on each light unit.
Strongly recommended.
2010 RS6 plus Avant, MRC Stage 2 747bhp 1059Nm
2008 Aston Martin DBS Volante
2001 Discovery 2
Jim Haseltine
Post by Jim Haseltine » Sun Jan 15, 2023 9:16 pm
Ah, so you don't get the extra main beam unless you have the fogs on?
Phuketpaul
Post by Phuketpaul » Mon Jan 16, 2023 10:17 am
Exactly, HID startup is too slow for them to be used as a mainbeam flasher or quick mainbeam function - they need to be on and warmed up first to get the full benefit - unless you go to Bi-LED (instant on) as I am currently building for my DB9.
2001 Discovery 2
Jim Haseltine
Post by Jim Haseltine » Mon Jan 16, 2023 12:28 pm
I'd wondered about the response time. Pity. Although I've moaned about the awful main beams on my RS they don't really matter as I rarely need to use them in any car that has decent low beams. Think I'll stick with things as they are. Mind you, thinking back over the near 7 years I've had the RS I don't think I've ever used the fogs other than to test them before a MoT.
Phuketpaul
Post by Phuketpaul » Mon Jan 16, 2023 12:42 pm
Trups modified RS6 Headlights are much better than stock as he uses better projectors, so even just using the 1 set of lights both the dipped and full beam are better - when you switch both on, both dipped and full are really good, better spread, more ven lighting and brighter with a better cutoff
2001 Discovery 2
ATinOf
Post by ATinOf » Tue Jan 17, 2023 3:08 pm
Moneys earned in order to spend it Jim 😂
Jim Haseltine
Post by Jim Haseltine » Tue Jan 17, 2023 5:30 pm
It used to be - until I retired....
ATinOf
Post by ATinOf » Tue Jan 17, 2023 5:55 pm
Arent the fogs used as the courtesy parking lights that come on for a short duration when you get out? So youve actually used them every time you use the car? If so how does the Trups mod work with the courtesy feature?
IanH755
Post by IanH755 » Wed Jan 18, 2023 9:40 pm
No the courtesy lights are the normal headlights, the fog lights (front and rear) only come on when the headlight switch is pulled out to activate each of them (Off, Front Only, Front & Rear).
EDIT - NO IT ISN'T, I'M WRONG, ITS THE FOGS!
Jim Haseltine
Post by Jim Haseltine » Thu Jan 19, 2023 10:19 am
I checked this last night. It was unpleasant outside to I didn't look too closely but it did look like the courtesy lights were the front fogs, but running at low power. I'll take a closer look tonight.
Except for during a MoT test or maintenance that involves removal of the headlights, my switch is always set to 'auto' - a position from which you can't operate the fogs.
ATinOf
Post by ATinOf » Thu Jan 19, 2023 9:44 pm
Having checked owners manual I beg to differ Ian....
ATinOf
Post by ATinOf » Thu Jan 19, 2023 9:46 pm
So does this feature still work with the TRUPS mod?
Jim Haseltine
Post by Jim Haseltine » Thu Jan 19, 2023 11:24 pm
A closer look. It was both the fogs and the DRLs at the front but appeared to be low intensity. I also noticed that the lights were triggered by either of the front doors opening.
IanH755
Post by IanH755 » Thu Jan 19, 2023 11:48 pm
Jim - I suppose mine could be different after the Trups mod but mine are definitely the headlights, not fogs, for the courtesy lights.
EDIT - Talking rubbish Ian, it IS the fogs which light up!
Jim Haseltine
Post by Jim Haseltine » Fri Jan 20, 2023 9:52 am
That would make sense as the headlight HIDs would have been in use so wouldn't have to go through the ignition/warm up phase again.
Users browsing this forum: No registered users and 169 guests
