Squeaking brakes
I've spotted the same pattern. The squeeling went away on its own accord after a month of driving after fitting. However, with all the snow and ice that's about the squeeling is back ... roll on spring if it ever gets here.rs666 wrote: Mine are fine. It comes back now and again, normally when its wet and salty. That's the pattern I have been able to put together.
Rich.
tartan_rob
Mine squealed when first new. They were still doing it 500 mils later. Took them apart, copper greased everything and hadnt heard a peep until this morning. I think its related to how hot they are. After only trundling along for 10 minutes the squeal was very bad but after another 20 mins they seemed ok.
I trained as a tech at BMW in Enfield for a while, I was always told that it's a glaze over the surface of the pad. our cure was to take the pad out and rub some ruff sand paper on the braking surface to take the glaze off. And I have to say it always worked. As far as I know the squeeling is a result of prolonged hard braking before the pads have bedded themselves in. During test drives after jobs we would do very short hard stabs of the brakes to bed them in without heating them up too much. then leave a notice to take it easy for 100 miles or so. It's was a rare thing if we ever had come backs and only ever had to sort out the DIY jobs people had fitted correctly but not bedded in. It should only take ten mins a corner to do.
Dan
Dan
Users browsing this forum: No registered users and 148 guests
