Rear end suspension rebuild
ChrisA
Re: Rear end suspension rebuild
Post by ChrisA » Sat Dec 03, 2022 4:36 pm
Sxcarmyboi wrote:
Sat Dec 03, 2022 3:33 pm
I done a full resend rebuild a couple of years ago on my rs6 if you have any question.
I did have a second complete subframe that I stripped down, cleaned and then fitted all my parts to. The. One weekend me and a mate swapped them over
Cheers Wes. I’d love to build on a second sub frame but I’ve already got another project on the go that’s go a full front end rebuild (forge rebuild, rebuild twin turbos, IC, subframe drop, full powder coating and engine bay respray) on my 300zx which is sucking up most of my spare cash.
https://www.300zx.co.uk/forums/topic/16 ... k/page/15/
ChrisA
Post by ChrisA » Sun Feb 26, 2023 2:18 pm
I made a little more progress finally removing all the bushes from the upper and lower control arms along with the ARB links. Big thanks to Matt who has been reply to my texts asking for help. 👊
Mɐʇʇ
Post by Mɐʇʇ » Sun Feb 26, 2023 7:00 pm
It's not often I get an opportunity to tell people to "burn it with fire"
ChrisA
Post by ChrisA » Sun Feb 26, 2023 7:42 pm
You were very enthusiastic with you encouragement to perform said tast. 🤣
Mɐʇʇ
Post by Mɐʇʇ » Sun Feb 26, 2023 7:44 pm
Made even better by the fact that I was telling a fireman to burn it with fire.
ChrisA
Post by ChrisA » Sun Feb 26, 2023 7:58 pm
ChrisA
Post by ChrisA » Mon Mar 13, 2023 4:30 pm
When your refurb goes further than you intended and you realise you should have to loosened the collar before taking the coilovers and control arms off. Improvise, adapt, overcome!
Big thanks again to Matt!!! 👊
ChrisA
Post by ChrisA » Mon Mar 13, 2023 5:35 pm
I’ve loosened the bolts holding the drive shaft to the diff but they’re not parting. Is there something I’m missing or am I just being a pussy?
Mɐʇʇ
Post by Mɐʇʇ » Mon Mar 13, 2023 6:34 pm
Give it a tap. 20 years of rust sticking them together.
ChrisA
Post by ChrisA » Mon Mar 13, 2023 6:50 pm
Where should I tap it, do you think it splits after the disc closest to the diff?
Also any recommendations for the replacement?
https://m.autodoc.co.uk/car-parts/oem/4d0598103
Mɐʇʇ
Post by Mɐʇʇ » Mon Mar 13, 2023 7:29 pm
This should help explain. So the inner flange stays where it is, but the middle and outer should come off.
Chris 2.jpg (18.66 KiB) Viewed 1819 times
ChrisA
Post by ChrisA » Mon Mar 13, 2023 7:50 pm
Cheers Matt, that does make it clearer. (Must resist withdrawing bolt 10 to clean up the flanged shaft). 🫣
ChrisA
Post by ChrisA » Wed Mar 15, 2023 2:28 pm
Mɐʇʇ
Post by Mɐʇʇ » Thu Mar 16, 2023 12:09 pm
Good progress. While you're this far "up to your nuts in guts", you might as well drop the rear subframe and do that too. :biggrin3:
ChrisA
Post by ChrisA » Thu Mar 16, 2023 9:24 pm
Stop it. I can’t tell you how much <beep> the boss is giving me over this project. 🤦‍♂️
