Turbos - options.
5.0 V10 50v biturbo - 571 bhp
IanH755
Re: Turbos - options.
Post by IanH755 » Fri May 01, 2020 5:40 pm
FUBAR wrote:
Thu Apr 30, 2020 11:43 pm
Anyway, when it went back to MRC for a map tweak I never got a dyno sheet, they where more busy with invoicing the cost of an oil leak on their dyno. Only thing I got out of them was «it’s fine», after that silent treatment.
Yeah sadly that sounds about right for MRC over the past few years. I mean their "customer service" when something isn't right after they've worked on a car has always been an extremely low priority, and their "mechanical" work has always been adequate at best (compared to other specialists) but it was their mapping (something they were always extremely good at) which kept people coming back for more because that very rarely went wrong.
I think they have now pretty much swapped over to the RS3 fanbase now as I very rarely see anything other than those on their FB pages.
C6Dia
Post by C6Dia » Sat May 02, 2020 11:35 pm
That’s a shame to hear those experiences. I am currently using REPerformance for my build, great guy and fantastic service.
As for mapping I will be using another independent for software and see if MRCs results can be replicated. (Not knocking them)
My spec will be similar to other 900-1k power cars on here so I have a good benchmark. This is;
TTE1000
Wagner intercoolers
Porsche injectors
Colder spark plugs
RePerformance Gearbox
Aquamist Hfs
Custom 3.5” downpipes
Milltek Res Exhaust.
Unfortunately due to this virus nothing will happen quickly. However looking forward to the final results.
MY09 C6 AVANT 843bhp in progress
MY10 C6 SALOON MRC 775ps
MY15 D4 S8 MRC 676ps
MY14 F10 M5 DMS 748bhp
MY10 C6 RS6 SALOON MRC 719.9ps
RMC83
Post by RMC83 » Sat Jun 20, 2020 2:36 pm
TTE1000
Wagner intercoolers
Porsche injectors
Colder spark plugs
Aquamist Hfs
C6Dia,
Just wondering, how are you getting on with your upgrade, have you managed to get everything complete & dyno'd yet? Really interested to see how your getting on with the TTE1000's + Wagner IC combo?
Roy
C6Dia
Post by C6Dia » Sun Jun 21, 2020 9:29 am
It’s all coming together, hopefully within the next couple of weeks.
The car is currently with Peron having some custom 3.5” downpipes made.
A small production run of around 5 sets will follow and be for sale as mine will be used for development.
A great opportunity for those who want to go hybrid turbo in the future.
Once completed, back to Ricky for some final checks and then off to my tuner for mapping.
I am not chasing crazy HP but with this setup 9xx hp on pump should be easy.
welwynnick
The Power Race
Post by welwynnick » Wed Jul 08, 2020 9:18 am
Turbo Technik Hamburg and RS Engineers have been dropping hints about this for a while, but I just noticed they're now offering 1100 turbos, ball bearings to boot:
https://www.ebay.co.uk/itm/Upgrade-Turb ... 1438.l2649
https://www.facebook.com/watch/?v=1039656936399773
It's interesting to see how much bigger the turbine and compressor are than the journal bearing turbo - I'd love to know what that is.
IanH755
Post by IanH755 » Wed Jul 08, 2020 3:47 pm
Those new bearings look very nice in the FB post. From the eBay advert the spec gives fairly minimal technical info, just the usual "it's uprated" etc but with no flow measurements etc to judge how good it'll be -
The OEM IHI 07L145701J & 07L145702J turbochargers have been optimized with the following changes:
  • milled Extended Tip compressor wheel with the latest compressor geometry
  • gap optimized by CNC-turned compressor housing and exhaust housing
  • reinforced ceramic ball bearing
  • 9-blade performance turbine
  • machined intake pipes
  • edited outlet
  • edited intlet
  • reinforced pressure can
  • fine balanced up to 0.05g
  • own production
  • Plug and play assembly
welwynnick
Post by welwynnick » Sat Aug 15, 2020 7:37 pm
RMC83 wrote:
Thu Apr 16, 2020 6:06 am
welwynnick wrote:
Wed Apr 15, 2020 11:53 pm
JD Engineering tuned an RS6 stage 3 TTE1000 to 973 bhp / 1065 Nm.
I presume the boost was held back to work with a stock gearbox.
There are quite a few stage 2 cars with stock turbos and 'boxes that make that kind of torque.
https://www.audi-sport.net/xf/threads/t ... rs.383918/
Nick
Do you have any further info on this car, as it seems this set up would be similar to what i'm planning. Look at where the power & torque lines cross... :D
Seems a lot of power to have using the stock GB, so it would be good to find out more about this car & whether the GB held up okay.
If i dial my set up back to 850hp, i'll probably do a dyno run to try & hit 900+hp just for the fun of it...then dial it back, so maybe this is also what they did & the final set up for the road, in terms of hp was a bit lower.
Anyway...as i said...it would be good to find out more.
Does anyone know the owner?
Roy
I found some pictures of the exhaust system. Apart from the X-over it looks really good.
https://www.facebook.com/JDEngineering. ... =3&theater
https://scontent.fltn1-1.fna.fbcdn.net/ ... e=5F5F1D2A
Nick
RS6-T28RPH
Post by RS6-T28RPH » Wed Dec 16, 2020 10:08 pm
Hows your build going? Once I have finished firefighting oil leaks and pipes mine is off to Ricky also and practically identical to yours except 3" peron downpipes linked up to 3" kwe cat back exhaust as wanted to drop the x pipe part.
Esben Business IT Solutions - http://www.esben.co.uk
Esben Remapping - http://remap.esben.co.uk
2015 BMW X6 M50d (wife-transport, not allowed to touch :cry: )
2008 RS6 Avant Phantom Black - MRC Stage2 (ecu, tcu & 2nd cat bypass) 730 PS/1017 nm
2006 BMW 535d Pre-LCI - Stage 1 (340bhp)
2003 VW Polo 1.4Tdi (3pot shitbox) tuning project, was 73bhp, now 120bhp, aiming for 160bhp before it goes bang! (put in the bin)
cammmy
Post by cammmy » Thu Oct 20, 2022 1:28 pm
Reviving this one as I'm mulling over whether to do turbos when I eventually have to drop the engine on mine and have a couple Q's
What supporting mods are required for TTE1000's? I see intercoolers and exhausts mentioned but not so much on fuel pumps and injectors?
Seems the common failure on the standard box is a double kick down snapping shafts. Does anyone now if it's possible to edit out this behaviour in a trans tune? I think upgrading the box as well would be out of reach (is anyone able to say what it costs?). I would likely just have the tuner take it to whatever the generally accepted safe torque limit is and try hold it there.
welwynnick
Post by welwynnick » Thu Oct 20, 2022 1:39 pm
There seems to be a pattern of behaviour where the box holds up to 1100 Nm OK, but if you go to 1200 Nm things start going wrong.
Nick
cammmy
Post by cammmy » Thu Oct 20, 2022 3:58 pm
Cool, thanks. Are the stock pumps and injectors up to delivering 1000hp? I'd be pleasantly surprised if they are.
welwynnick
Post by welwynnick » Thu Oct 20, 2022 4:24 pm
There are low pressure and high pressure pumps, and I'm fairly sure you would need to upgrade the former. Many people will tell you that either the injectors or the HP pumps also need to be upgraded, but I have a suspicion they're pulling the wool over people's eyes and taking advantage of the confusion between direct and indirect injection. Problem is it's difficult for punters to find out on their own. Not something you want to take a risk on, though. Last thing you want is an engine going lean at 1000 hp.
cammmy
Post by cammmy » Thu Oct 20, 2022 4:27 pm
Indeed, assuming the feed pumps are accessible, they should be easy and cheap enough to upgrade. HP pumps not so much. I believe it was about £450 for one pump when I looked for an S3.
cammmy
Post by cammmy » Thu Oct 20, 2022 4:43 pm
Prices vary wildly but this seems the best deal.
https://www.bar-tek-tuning.com/5l-tfsi- ... mp-bar-tek
welwynnick
Post by welwynnick » Thu Oct 20, 2022 5:09 pm
I think at heart they're all based on the Autotech kit.
Users browsing this forum: Google Adsense [Bot] and 22 guests
