Is there anything behind here that can be replaced.
Frazz82
Post by Frazz82 » Mon Jul 11, 2022 12:45 pm
Trying to trace a knocking at low speeds when coasting or with light pressure on the accelerator.
All arms replaced an tight, wheel bearing isnt noisy or has any play in it and the driveshaft seems in good condition with no play an packed with grease.
Is there anything behind this joint that can replaced as there is abit of play both sideways and in an out.
Frazz82
Re: Is there anything behind here that can be replaced.
Post by Frazz82 » Mon Jul 11, 2022 12:52 pm
Frazz82
Post by Frazz82 » Mon Jul 11, 2022 1:15 pm
I ve just looked inside the inner joint an the grease is very watery wonder if this could be the problem.[attachment=0]20220711_130728.jpg[/attachment]
Post by Shoppinit » Mon Jul 11, 2022 1:59 pm
Yeah, there's a bearing in the diff that can go. YOu can get to one side with the engine remaining in the car. Can't remember which. Mavada had his done, IIRC.
Have you checked your steering racks bolts are all tight?
Frazz82
Post by Frazz82 » Mon Jul 11, 2022 5:48 pm
The rack bolts are tight.
I have the inner in bits now an the 3 bearings can be removed quite easily and the whole thing feels worn so I am hoping this is the cause of the knock. Is the watery grease normal I thought it should be thicker like the outer grease.
Someone said the engine mount maybe on its way out which I know could do with changing but waiting till cambelt is done.
Mɐʇʇ
Post by Mɐʇʇ » Mon Jul 11, 2022 7:42 pm
ECP carry some GKN bits for these, one of my CV joints is a GKN one that I replaced. They are good quality and it’s always nice when a bit is easy to get.
Mɐʇʇ
Post by Mɐʇʇ » Mon Jul 11, 2022 7:43 pm
Mm. Just checked. Sorry. It’s the outer they have and I think you’re wrestling with an inner there?
Frazz82
Post by Frazz82 » Tue Jul 12, 2022 7:38 am
Yer I am assuming the cause of my knocking is the inner.
Foxmeister
Post by Foxmeister » Tue Jul 12, 2022 10:11 am
I also have some slight vibration under acceleration, i think i have issues with my joints that need looking at but not had time to strip them off yet, which side is this you have off?
I would say the watery grease is not a good sign, should be packed as normal
Post by Shoppinit » Tue Jul 12, 2022 10:15 am
Vibration on acceleration is a sign of worn inner CV joints. Amongst many other things.
Foxmeister
Post by Foxmeister » Tue Jul 12, 2022 4:09 pm
Yep, thats where i need to be looking next on mine Shopp, but i might get some front bearings as PM and do them at the same time also
Post by Shoppinit » Tue Jul 12, 2022 4:16 pm
I only change wheel bearings if I think there's a problem with them. They almost always give plenty of warning. Although the other day I thought the Passat had a failing bearing but it turned out to be a deformed tyre.
Foxmeister
Post by Foxmeister » Wed Jul 13, 2022 8:17 am
The ABS lights etc used to flicker when not used in a while, sometimes contact ring breakdown or rust can cause that, and i do get a rotational grumble although they arent terrible yet, more of a preventative measure than anything and SKF items are reasonably cheap enough
Frazz82
Post by Frazz82 » Wed Jul 13, 2022 6:27 pm
Riiiiiiight so everything on the osf has been replaced apart from the outer c.v joint. I still have the knocking at low speeds but its only once the car has been driven for afew miles an everything's warmed an loosened up.
I do have a fault code 17985 which is the right hand engine mount. Could this be causing the knocking. Its going to get changed when I do the cambelt soon.
How much play should there be in front diff shaft that connects to the driveshaft
Foxmeister
Post by Foxmeister » Sun Jul 17, 2022 11:49 am
Which steering rack bolts are we talking about here? Are they obvious? Got me paranoid now, I’m gonna check mine if this is a common issue
Users browsing this forum: B_O_N_K, Cunningstunt and 119 guests
