Vag Com Fault Codes
Vag Com Fault Codes
Guys,
I ran vag com on my car the other day and done a search for fault codes and the following fault codes appeared
vag com alerts
DTC REsults
Address 01: Engine
17865 - Exhaust Gas Temp Sender 2 (G236): Open or short to Plus
P1457 - 35-00 - -
Address 55:Xenon Range
01538 - Motors for Headlight Reange Adjustment (V48) / V49
29-00 - Short to
I have searched the site but have not found the answers to the following questions. I am going to relace the gas temp sensor but does anybody know which side this refers to (near side or offside bank?)?
With the Xenon error code if the headlights are set up in the right position then I am assuming that this is not an issue? Is that correct?
Thanks,
Brad
vag com alerts
DTC REsults
Address 01: Engine
P1457 - 35-00 - -
29-00 - Short to
Thanks,
Brad
RE: Vag Com Fault Codes
According to SS198, G236 is passenger side, assuming yours is a RHD version.
Re: Xenons they should be fine, other drivers will soon let you know if there is a problem with them. Mos garages have a quick check chart on the wall you can drive up to to verify.
ive done both of mine..the drivers side when the V (inlet manifold) was off and the other side when it was back on..the passenger side is the worst to do but it is dooable..where abouts are u located??anywhere near south london..
GARTH ROAD MOT CENTRE LTD
020 83353032
020 83353032
Thanks S4woody.
I am based in Maidstone in Kent so not far away.
I will probrably get a mechanic friend of mine to do it just wondered how much work was involved for him and if I could give him any pointers to make it easier?
Waiting on a price from Vagparts at the moment for the sensor.
What are the implications of this faulty sensor?
Thanks,
Brad
Thanks,
Brad
theres 2 10mm bolts 2 remove off the sheild then u can get 2 it..its tight but can be done..unplug it undo the sensor then refit new then fit back bolts then done..well it sounds easy but just fiddly..
020 83353032
020 83353032
V48 and V49 are the range control motors, so the fault is either in one of the motors, or the wiring between J431 (the control unit) and the motor. When you first turn your headlights on you should find that the beams come up from the rest position, taking about a second - does this happen? Is it only one light which does this?
07 Mitsubishi Pajero(Shogun) 3.2 Di-D
Suzuki Carry 660
Suzuki Carry 660
Peter
Not sure I think that the lights rise slightly ( Iwill confirm tonight), and the offside seems slightly higher than the nearside (about 1/2 inch or so ). Where is the control unit located? If the beams are within the MOT settings is this anything to worry about, and if not within the settings then can they be set manually?
S4 Woody
Thanks for the info on the sensor removal.
Brad
S4 Woody
Brad
thats a possibility cos i did that when i changed my oem sidelight bulbs 4 led,s..i soon sussed it out and refitted the wire..and the led sidelight bulbs look like baby xenon lights..wicked..
020 83353032
020 83353032
Users browsing this forum: No registered users and 40 guests
